Old 05-15-2018, 09:24 AM
noah330 noah330 is offline
Default Drum Replacement - What's everyone using?
It kind of blows my mind that in HD (or Ultimate, whatever it's called these days) we don't have a simple audio -> midi tool but I was wondering what everyone was using for this task.
Normally I don't replace drums but I'm mixing a project that really needs some help.
I don't need any libraries, just a simple audio -> midi convertor. I have Komplete and a bunch of drum libraries.
Apple M1 Mac Studio (base model)
ProTools Carbon w/SSL XLogic MADI-AX
Instagram:
https://www.instagram.com/sparkletune/
Old 05-15-2018, 10:14 AM
deanrichard deanrichard is offline
Default Re: Drum Replacement - What's everyone using?
There are many, but I have used Drumagog for many years. It works well when I need to do drum replacement.
Old 05-15-2018, 10:47 AM
Extreme Mixing Extreme Mixing is offline
The Massey DRT audio suite plug is great, and very accurate. I think the free demo version lets you harvest the MIDI. The pro version lets you use your own sample to replace the drums. It works great.
Steve
Steve Shepherd
Extreme Mixing
Old 05-15-2018, 11:22 AM
skizzo skizzo is offline
I would argue that drum replacement is not exclusively audio to MIDI converting. Plugins such as Drumagog or Sound Replacer work with audio to audio.
Before Superior Drummer 3 was released I used a stand alone version of Toontracks "Drum Tracker". This converts audio to MIDI and it is possible to use it on just OH's but will require much more user intervention to add/delete missing/false trigger points.
Drumtracker is also now included as part of Superior Drummer 3 so if you have or get that plugin, which can also be standalone, that will cover your needs also. But if you don't want more libraries or happy with current plugin/program then SD3 is too costly for what you need
Those are basically the only replacement plugin/programs I have experience with. I would get Drumtracker from my personal use. But its been several years since I utilized Drumagog so newer versions could offer a lot more than I am aware off. Check them out and make the call based on your wants
Mac Pro '09 - 5,1 - Dual Hex Core X5680 3.33 ghz CPU - 48GB RAM
970EVO 500GB (10.13.6) - 1TB WD Black HDD (Samples) - 6TB Toshiba HDD (Backups) - 500GB Glyph GT050Q (Legacy sessions & backups) - 3TB Glyph Studio (Main audio/sessions)
HD5770 GPU
OSX 10.13.6 - Pro Tools 2018.12 - Presonus Studio 192 / Digi 003 Rack+
Focusrite Clarett OctoPre - AKG HPE6 - DBX160A - WA76
Old 05-15-2018, 11:43 AM
Thanks everyone! I remember gating drums and triggering samplers in the past.
I tried the Slate demo but didn't really dig it. Nice to see some options.
Appreciate the help!
Instagram:
Old 05-15-2018, 11:49 AM
YYR123's Avatar
YYR123 YYR123 is offline
Yep I use trigger and it works great.....like you said you can create midi tracks of your song from the Audio file...
Really nice
Daniel
Old 05-15-2018, 12:17 PM
tope d's Avatar
tope d tope d is offline
Here's my workflow for replacing/mixing analogue drums with digital..
Recorded Drum Audio Track (separate/individual drum/cymbal recorded) > (Plugin) Drumagog > routed to New Midi Track/Instrument Track > (plugin) Addictive Drums 2. :)
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 05-15-2018, 01:26 PM
climber climber is offline
Been using Slate Trigger since version 1 and it's always worked great for me.
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 05-15-2018, 06:11 PM
AlexLakis AlexLakis is offline
+1. Barely have to tell it what to do, it just does it.
Old 05-15-2018, 07:21 PM
I also like and use Trigger a fair amount, but since SD3 hit, it has become a favorite, at least unless I need samples from my Trigger library. I used to use Drumagog a lot with version 4, then some with Drumagog5, but something went sour with it and I never got it to work again(every time I tried to insert it, I'd get a -7054 error). Uninstalled, updated, reinstalled multiple times and never got it to work again(and support was a bust)
Drum Replacement in PT? jimbojimbo Pro Tools 10 20 03-07-2012 03:00 PM
drum replacement MX582 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-06-2006 10:10 AM
Drum Replacement vocalize Pro Tools TDM Systems (Mac) 9 09-20-2005 12:19 AM
Drum Replacement ivet Tips & Tricks 5 04-30-2001 11:48 AM
Drum Replacement ivet General Discussion 0 04-26-2001 09:25 AM
