Old 01-22-2014, 11:05 AM
playground_strifer's Avatar
playground_strifer playground_strifer is offline
Default Scarlett 2i2: multiple issues with PT11
Hi folks.
I recently purchased PT11 for a friend and I have installed it on their laptop:
Specs: Acer-Aspire E1 - 570, i3 CPU, 8GB RAM, Windows 8 64-bit.
I have installed the drivers for the scarlett and ASIO4ALL.
I'm having so many problems with the Scarlett. Initially I blamed Windows 8 as it is a complete nightmare but it seems the interface may be to blame.
  • I cannot receive and playback with the play and stop button both flashing.
  • If I record enable and try and record it crashes straight away.
  • When a track is record-enabled all I that is outputting is a distortion.
I have disabled dynamic plug-in processing, check to "ignore errors". I have the latest drivers installed, the sample rates between interface and PT are matched and I have properly configured the IO.
I have also tried running PT in compatibility mode to no avail.
Stuck... help please!
Hardware Interface: Digidesign 002 (Rack)
System #1
Macbook Pro, Retina, 15 inch, Late 2013
Processor: 2.3 GHz Intel Core i7
Memory: 8 GB 1600 MHz DDR3
Graphics: Intel Iris Pro 1024 MB
Software: OS X 10.9.2
System #2
Dell XPS8300, 2010
Processor: i7 2600 3.40GHz 4 Cores
Memory: 12GB DDR3
Software: Microsoft Windows 7 (64-bit)
Old 01-22-2014, 11:26 AM
Default Re: Scarlett 2i2: multiple issues with PT11
The Scarlett works fine with my own system (see specs below) and the ASIO4ALL driver runs on the WIndows 8 machine without conflict.
So, is it Windows 8 or PT11 that is causing the issue?
System #1
System #2
Dell XPS8300, 2010
Memory: 12GB DDR3
Old 01-22-2014, 11:49 AM
My my...
... changed the buffer rate to 512 and it worked! I also noticed there is a playback and recording sample res to match in the Control Panel > Sound.
System #1
System #2
Dell XPS8300, 2010
Memory: 12GB DDR3
Old 01-22-2014, 02:47 PM
zolko zolko is offline
Why do you need Asio4all in your setup?
PT11.0.2 full ed. + Focusrite Scarlett 2i4 issue Roland Shaak Windows 3 08-20-2014 11:57 AM
Scarlett 18i8, PT11 6101 error thecaptainandme Pro Tools 11 2 02-06-2014 04:20 PM
Which new Mac Pro to get: and how PT11 handles multiple cores Markrosoft macOS 9 11-14-2013 09:13 AM
Two issues one might be PT11 bug propower Pro Tools HDX & HD Native Systems (Mac) 4 10-13-2013 11:56 AM
Focusrite Scarlett 2i2 Driver issues in Pro Tools 10 jeremyguy Windows 8 10-02-2013 09:54 AM
