Old 02-25-2012, 04:34 PM
Winton Winton is offline
Default Hardware menu not accessible
Hi all, I was tracking for the first time today since upgrading from 8 and was to use my usual pres in via adat, but when clicking on "setup>hardware" to load the menu and set the clock source there was nada. This is with a digi002R, windows 7 pro 64-bit & new pt10 update installed.
I have just uninstalled and re-installed everything but still no menu opens when I click. Everything else is working fine. Any ideas?
talk is cheep
Old 02-25-2012, 05:29 PM
Default Re: Hardware menu not accessible
Is the 002r the selected audio engine? Sounds like PT reverted to the onboard audio(which doesn't have anything past analog 1&2.
Old 02-25-2012, 05:45 PM
Hi albee, it is selectedin windows and plays audio from other apps fine. It even allows the adat ins as input channels. PT will just not let me access the usual hardware setup page. (if the clock is not set to adat I gets clicks and pops on the adat audio)
talk is cheep
Old 02-25-2012, 08:36 PM
DHL DHL is offline
Sounds like you need to update the 002 drivers.
Daniel
Asus P6X58D-E, Intel i7 930, 12 Gb Corsair XMS3 DDR3
2 WD Black Cavier 640 Gb SATA 3Gb/s 32MB Cache
Windows 10 Pro
Old 02-26-2012, 06:20 AM
I've already updated the drivers, same thing. This looks like a software issue as the hardware should not affect the ability to view a menu in the software?
talk is cheep
Old 02-26-2012, 07:55 AM
DHL DHL is offline
I just updated from PT 8 to 10 last week and I had the same issue with not being able to view the hardware menu. I updated the drivers for my 003r and that solved the problem.
Daniel
Windows 10 Pro
Old 02-27-2012, 07:08 AM
This appears to be an issue with 002's and pt10 only.
I have found a gearslutz thread which is identical to this one (003 user problem solved... except for the OP)
http://www.gearslutz.com/board/pro-t...wont-show.html
I hope avid address this in the next update...
talk is cheep
Hardware menu won't open chalz2502 macOS 2 12-21-2013 08:02 PM
11r not seen in PT 9 Hardware pulldown menu otna48 Eleven Rack 13 12-22-2010 06:28 PM
Menu BUG...Menu FREEZES...Menu LOCKS UP...Restart Pro Tools! a2zproductions Pro Tools TDM Systems (Mac) 16 05-08-2008 09:30 AM
Help Menu Not Accessible JHB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-13-2007 05:01 PM
Missing"Other" Button in Hardware Menu/5.0 David Horner Pro Tools TDM Systems (Mac) 0 04-09-2000 12:54 PM
