Old 11-10-2011, 07:47 PM
bmenchen bmenchen is offline
Default 2 issues in pt9 allocating space
Using Pro Tools 9 latest ver
using Focusrite DSP24 pro
1st error cant allocate space for recording yes preferences are set to allow open
recording and yes drive is not full yes R R are set in the workspace
Sometimes if I add a track or switch to another track it will allow me to record
but it don't work all the time.
Second error when I hit record it wont record its like I just hit play This is extremely annoying having stop and hit record sometimes up to six times before it will actually record
I am working on 3 serious projects and this is slowing me down big time
SiSoftware Sandra
Computer
Processor
Model : Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz
Speed : 3GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 2 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing
Computer
Mainboard : Asus P6T SE
BIOS : AMI 0808 03/08/2010
Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 6GB DIMM DDR3
Chipset
Model : ASUS X58 I/O Hub
Front Side Bus Speed : 2x 2.41GHz (4.82GHz)
Chipset
Model : Intel Core Desktop (Bloomfield) UnCore
Channels : 3
Memory Bus Speed : 2x 536MHz (1GHz)
Memory Module(s)
Memory Module : Corsair CM3X2G1600C8D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5)
Video System
Video Adapter : ATI Radeon HD 5700 Series (800 SM5.0 850MHz, 1GB DDR5 4x1.2GHz, PCIe 2.00 x16)
Graphics Processor
STREAM Processor : ATI Radeon HD 5700 Series (800SP 10C 850MHz, 1GB 4x1.2GHz)
Compute Shader Processor : ATI Radeon HD 5700 Series (800SP 850MHz, 1012.4MB 4x1.2GHz)
Storage Devices
Seagate ST3750640AS (750.2GB, SATA300, 3.5", NCQ, 16MB Cache) : 699GB (C:)
Seagate ST3500320AS (500.1GB, SATA150, 3.5", 7200rpm, NCQ) : 466GB (D:)
ASUS DRW-24B1LT (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:)
ASUS BR-04B2T (SATA150, BD-R, DVD+-R, CD-R, 2MB Cache) : N/A (F:)
Logical Storage Devices
System Reserved : 100MB (NTFS)
AUDIO (D:) : 466GB (NTFS) @ Seagate ST3500320AS (500.1GB, SATA150, 3.5", 7200rpm, NCQ)
Hard Disk (C:) : 699GB (NTFS) @ Seagate ST3750640AS (750.2GB, SATA300, 3.5", NCQ, 16MB Cache)
Optical Drive (E:) : N/A @ ASUS DRW-24B1LT (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Optical Drive (F:) : N/A @ ASUS BR-04B2T (SATA150, BD-R, DVD+-R, CD-R, 2MB Cache)
Peripherals
LPC Hub Controller 1 : ASUS LPC Interface Controller
LPC Legacy Controller 1 : T0 A5-13
Audio Device : ASUS HD Audio Controller
Audio Device : Gammagraphx EG JUNIPER XT Audio Device [Radeon HD 5700 Series]
Disk Controller : ASUS 4 port SATA IDE Controller
Disk Controller : ASUS 2 port SATA IDE Controller
USB Controller 1 : ASUS USB UHCI Controller #4
USB Controller 2 : ASUS USB UHCI Controller #5
USB Controller 3 : ASUS USB UHCI Controller #6
USB Controller 4 : ASUS USB EHCI Controller #2
USB Controller 5 : ASUS USB UHCI Controller #1
USB Controller 6 : ASUS USB UHCI Controller #2
USB Controller 7 : ASUS USB UHCI Controller #3
USB Controller 8 : ASUS USB EHCI Controller #1
FireWire/1394 Controller 1 : ASUS VT6315 Series Firewire Controller
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : HP Officejet J3600 series (1200x1200, USB, Colour)
Printer : Adobe PDF Converter (4000x4000, Colour)
Network Services
Network Adapter : Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) (Ethernet, 100Mbps)
Network Adapter : Hamachi Network Interface (Ethernet, 100Mbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
[IMG] code is Off
TL Space Reverb issues pseradarian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-09-2010 05:23 PM
TL Space Installation Issues dmacintyre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-18-2009 04:00 PM
TL Space IR installing issues filosofem 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-20-2007 09:26 AM
Help with new drive & allocating space. Severe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-02-2005 11:23 AM
Pre-allocating disk space for recording 1m1 Pro Tools TDM Systems (Mac) 4 05-04-2004 10:14 AM
