Old 02-09-2011, 06:10 PM
LSJ LSJ is offline
Default Can't assign audio to new track for mixdown
Hi Folks,
I'm running into a very odd problem. I'm working in PT 7.4 on an HDIII system, PCI, mac G5. I'm at the end of a project that has taken years. I need to mix a song down to a stem and having a strange problem. All the tracks are set to output to A1&2 on the 192 and there is a master fader with that assigned output. To create a stem I'm:
1. Create stereo audio track.
2. Select inputs A1&2
3. Output 3-4 (not used on the 192)
And, I get NO signal on the audiotrack at all. Nothing. Not in record either. Even if I create busses on the channels I can't get any audio input to a track. I can assign Buss 20&21 on the channels and assign that as the input to the new audio track and can't a signal even though the send shows signal going out. I've never had this happen before. I'm inches from finishing a CD I've worked on for 5 years and this is driving me crazy. The audio plays back absolutely fine. Can anyone help? Thank you!
Old 02-09-2011, 07:29 PM
HD2 HD2 is offline
Default Re: Can't assign audio to new track for mixdown
Do not double post. look at your other post for the answer.
Create and Assign New Track from Track ZEROPRO Windows 2 12-05-2011 10:15 PM
cant figure out how to assign the optical in to a track? greglarson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-06-2010 12:00 PM
how to assign a plugin to a midi track shoog MIDI 3 12-01-2007 08:50 AM
Audition track assign in 7.1cs4 CD Productions Pro Tools TDM Systems (Mac) 4 03-22-2006 05:44 PM
assign one voice per track mario Pro Tools TDM Systems (Mac) 3 05-08-2000 01:31 AM
