Old 01-27-2008, 08:28 PM
paul_g paul_g is offline
Default Plugins on a mixdown track
Hi All,
Q about mixing down w/ plugins.
I want to mix down audio and aux tracks to a stereo audio track.
I would like to have Comp/Limiter on the final mix.
I'm guessing I should put the comp/limiter on the Master Fader track because I have low latency turned on...
If I put it on the stereo audio track that is designated for the mix down, the plugin becomes inactive. If I turn Low Latency monitoring off, the signal from my ext sequencer is not synched up with the audio.
So, by placing plugins on the Master Fader, will that send the 'effected' signal to the final mix down track?
Thanks!
Mid-2007 2.4 ghz Intel Core 2 Duo iMac
OS: 10.7.5 (Snow Leopard)
4gb (667 MHz DDR2 SDRAM)
LaCie Audio Drive - FW800
DigiDesign 003 Factory PT10.3.10
PreSonus DigiMax FS
Dynaudio Monitors and KRK Sub
Line6 HX Stomp
Old 01-27-2008, 10:31 PM
DKM DKM is offline
Default Re: Plugins on a mixdown track
Yes, however a couple things to remember, in order to bounce to disk Aux inputs tracks coming in live (in real time)
low latency must be off. You can fix your midi timing problems by setting your playback buffer to 128 or lower providing
your computer can keep up. The lower the better. 32 samples if you run PT 7.4. (You may want to pre-record your midi tracks in to a stereo audio track before mixdown if you have a slower computer or a lot of plugs/instruments running. Deactivate all other tracks then record midi stuff in)
Don't forget to put a dither plug on your master fader (last in the chain) if you are changing bit depth/sample rate.
Can't assign audio to new track for mixdown LSJ Pro Tools TDM Systems (Mac) 1 02-09-2011 07:29 PM
Disappearing Track in Mixdown raiderrob 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-07-2010 04:00 PM
Plugins on Master Fader or Main Mixdown Track studioslave77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 12-20-2007 01:02 PM
Mixdown recording to track tonzauber 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-03-2006 04:05 AM
Plugins used during mixdown demo at NAMM rmandelbaum Tips & Tricks 0 03-03-2006 08:09 PM
