just canīt fix it..
hi.
first of all my english is really basic, sorry, so read this slow and carefully :P long time ago i installed my digi001 on a PC with PTLE6.4. rarely, my protools works fine and i was very happy!. the problem starts when i bought a new HardDisk and install it. i get the famous DAE error -6042 (PCI bus too busy... blah blah blah) . when i disconnect the second harddrive.. PT works fine!. so, the problem is the damn second harddrive, maybe the problem is because the 2 harddrives are from different manufacturers . what im doing wrong???? salutes.. Roberto. |
Re: just canīt fix it..
Mixed manufactures are not the problem.
Tell us more about your 2nd drive. Internal or external? ATA or SATA? If internal, is it a slave or on it's own cable? If external, Firewire or USB? How is it formatted? (FAT32, NTFS, basic or dynamic) |
Thanks JMS40 for the fast reply
the second HDD is internal ATA, and slave on IDE 1 (where the 1st harddrive is connected).. Maxtor 80gb. It was from another PC, so isnt formatted (still has windows on it ) .. should i format it? mmmm my gear i havent post it because i dont remember it :P... motherboard: ASrock k8update Processor: AMD64bit 2.2ghz. RAM. 1gb salutes |
yes you should reformat it or at least delete all the data. You also need to make sure you put the jumper on the correct pins for slave or cable select operation. Then make sure that the drive is operating in DMA mode.
Yes, format the drive.
albee's advice is correct. I'll add, if it's possible to get it off on it's own IDE port, you might see improved performance. |
thanks guys.. i will post back with the results...
salutes |
