Old 01-02-2020, 04:25 PM
rourketown rourketown is offline
Default HDX in new Mac Pro/Catalina
I have the new Mac Pro (2019) running Catalina. I installed my HDX card and have installed the latest Avid/PT software and HD Drivers (2019.12) still my HDX card is not being seen inside of Pro Tools Hardware Setup or I/O setup. I have not seen any threads on this.... Are the HDX cards supported in Catalina?? Can anyone please help
Old 01-02-2020, 04:45 PM
uptheoctave uptheoctave is offline
Default Re: HDX in new Mac Pro/Catalina
They aren't supported yet, but I've got mine working in a 16 core, 160GB RAM, 4TB model.
Which slot did you put yours in?
Mine is in slot 5.
How are you powering the card?
Old 01-02-2020, 04:47 PM
Studio Dweller Studio Dweller is offline
The new Mac Pro isn't officially supported yet, but I have a single HDX card installed in slot 6 (two slots below the Apple IO card) and it's working fine. Pro Tools 2109.12 did a firmware update on the card during the first launch.
Did you get the Aux Power Cable Kit? You will need it. Specifically, it's the one labeled "Cable Set 3 - PCIe Aux Power Cable 6-pin to 6-pin".
Larry
Cellar Dweller Productions
PT 2020.3.0 HDX, HD IO 16x16 analog, 192 I/O, Control|24
Mac Pro 2019 16-core, 96GB RAM, OS 10.15.2
Old 01-02-2020, 05:15 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Slot 6 maybe-
Old 01-03-2020, 07:52 PM
rmccam rmccam is offline
Hi All,
I’m looking to pull the trigger on a new Mac Pro to run my HDX system. For those who have got it running, how’s stability been?
Thanks,
Ryan
Ryan McCambridge
Producer • Sound Designer • Mixer
Old 01-04-2020, 05:49 PM
Carl Lie Carl Lie is offline
Originally Posted by rmccam View Post
Hi All,
Thanks,
Ryan
Look for a thread called "2019.12 Discussion" A few folks wrote in there about the new Mac Pro.
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 01-04-2020, 07:15 PM
Will do. Thanks Carl.
Ryan McCambridge
Old 05-13-2020, 01:37 PM
Dizzi45Z Dizzi45Z is offline
I'm running into the same situation as the original poster. I have installed as Avid Recommends here (slot 2):
Apple Mac Pro 7,1 Slot Order
In the second slot. I am using the Belkin AUX Power Cable Kit for Mac Pro or one 8-pin to dual 6-pin cable and have the other end of the power cable in the Mac Pro in slot 1 (I've also tried slot two).
I've installed the HD Driver multiple times, restarted multiple times and no luck. The HDX Driver just won't show up.
I'm on a 16 core with 160 GB of memory. The mac shows that I have a card installed in Slot 2.
It sounds like some of you may be having success in other slots. When I get a moment, I'll try those other slots and report back.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 05-13-2020, 09:39 PM
Well, interesting enough, I found that when I went into System Preferances - Security & Privacy and under the General Tab, it said it had denied Avid from installing because it was an unidentified developer. So after I told it to trust Avid, I installed it yet again, restarted my computer and it was there.
So if you are running into this problem, check Security & Privacy settings.
160 GB RAM
macOS 11.7.4
Old 08-23-2020, 09:43 PM
MixerGuy MixerGuy is offline
is this still a common issue ? aug 2020.
thanks
PT and Catalina gub macOS 3 12-21-2019 12:48 AM
Catalina cqd Pro Tools 2019 10 10-09-2019 01:37 PM
Catalina Ryan Young Pro Tools 2019 6 06-06-2019 10:20 PM
