Go Back   Avid Pro Audio Community > Legacy Products > ProControl, Control|24, Command|8
Old 06-29-2014, 08:08 AM
Armando Armando is offline
Default Control 24-Want to remove side panels and armrest for resurfacing
Hello,
Has anyone removed either the side panels or armrest or both on their Control 24 for refinishing??
I think I remember seeing the armrests were once available thru Digi/Avid.
I plan on refinishing these parts, as the sticky, dust collecting "rubber-like" texture needs to go.
Thanks in advance!!
Armando
Old 07-03-2015, 09:41 AM
Artysan Artysan is offline
Default Re: Control 24-Want to remove side panels and armrest for resurfacing
Hi Armando,
I did just what you are describing and it was not easy. Needed right angle screwdrivers, flex-bit adaptors, mini-vicegrip pliers and lots of time. I did eventually get it apart and cleaned and it is very satisfying to get that crap off.
I have since done my other one WITHOUT removing the pieces and this was equally difficult, primarily because you can't go wild on those parts while they are attached, and going wild is what it takes to remove that garbage. I used every solvent known to man, including some that required rubber gloves. I'm estimating each method required about 20 hours of work!!
Peter
Peter Yianilos
Artisan Mobile Recorders
Old 07-03-2015, 09:42 AM
By the way, no refinish is necessary. All parts have a nice satin plastic finish that I have found quite suitable.
Peter Yianilos
Old 07-04-2015, 12:58 PM
Originally Posted by Artysan View Post
Hi Armando,
Peter
Thanks Peter!
What solvent did the trick for you?? Thanks in advance!!
Armando
Old 09-08-2015, 10:37 AM
Studio Dweller Studio Dweller is offline
I recently removed the rubber coating from my armrest. Like pretty much everyone else's, mine had become a tacky dust magnet. I used a total of three Scotch Brite "No Scratch" sponges, a bucket of diluted Spic and Span and some elbow grease. It came off pretty easily and did not take very long. I didn't remove the armrest either. I used a minimal amount of liquid and was very careful about not getting any beyond the edge of the armrest. Worked great and the plastic surface underneath looks good. I don't feel the need to refinish it with anything.
Larry
Cellar Dweller Productions
PT 2020.3.0 HDX, HD IO 16x16 analog, 192 I/O, Control|24
Mac Pro 2019 16-core, 96GB RAM, OS 10.15.2
Old 09-08-2015, 10:54 AM
Thanks!
What color is the armrest without the coating?
Also, is it plastic or metal?
Thanks again!
Armando
Old 09-08-2015, 12:22 PM
The armrest is semi-shiny black plastic. Here's a pic that I think is representative of how it actually looks.
Larry
Old 09-08-2015, 01:39 PM
That's awesome! Thanks!!
By the way, how are the sides of your desk holding up?
Armando
Old 09-08-2015, 02:39 PM
My Control|24 is an Argosy console so although the sides have also gotten a little tacky, they haven't accumulated the crazy amount of dust that the armrest did. They're not really exposed so it hasn't been a big concern for me.
Larry
Side\End plastic panels for my control surfaces RuffinMedia Artist Series 0 01-05-2012 06:16 PM
Cleaning older Control 24 Armrest Armando ICON & C|24 6 09-13-2010 04:24 PM
Control 24- armrest and faders stainless ICON & C|24 5 04-09-2010 11:32 AM
D Control 32 which side volodia ICON & C|24 1 11-27-2005 09:58 PM
Control Panels Severe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-03-2002 02:08 PM
