Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 02-01-2014, 02:29 PM
mandal mandal is offline
Default ...add more inputs to OMNI
Gurus
I'm running PT11 HD Native and OMNI using the PCIe card.
I have 4 analog inputs and 4 digital (max 8 input)
How to add more analog inputs ?
I guess I can add a Behringer ADA8200 or Saffire or MOTU and connect via ADAT to my OMNI - but is it possible to use the PCIe port2 AES ?
Please advice...
Can you recommend me a tried & tested solution ?
Thanks
Mandal
Microsoft Windows 11 Home 64-bit OEM DVD
Avid OMNI PCIe
Pro Tools Ultimate 2023.12
CPU: Intel Core i9-10980XE
Motherboard: Gigabyte X299X AORUS MASTER E-ATX
RAM: 64 GB Crucial Ballistix Sport LT DDR4
Screen card: MSI GeForce GTX 1660 VENTUS XS OC
Old 02-01-2014, 02:54 PM
propower propower is offline
Default Re: ...add more inputs to OMNI
Sure-
Hang a 192 off the expansion port
Hang AVID I/O off expansion port
Hang ISA 428 off ADAT ins
2017 27" iMac 3.8GHz i5, 1TB SSD
Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB
Musician: http://www.ivanlee.net/
Design Engineer: http://www.propowerinc.com/resume.html
Old 02-01-2014, 03:25 PM
Originally Posted by mandal View Post
Gurus
/snip/
Mandal
The Omni is an 8x8 IO box, you cannot add any more inputs going thought the Omni unless you give up some of the existing digital inputs--is that what you are asking or do you want to add more than 8 total inputs?. Otherwise, as pointed out you can add one or more other Digilink compatible interfaces and use them all together (that other interface cannot be another Omni, you can only have one per system).
Old 02-01-2014, 11:38 PM
Thanks...
I just want to consider all the options...and yes I know that OMNI is an 8x8 IO box
I guess a total of 8 analog input is OK for me - and I just wonder how to find the best solution...
1) Replace 4 of the digital inputs with 4 analog using ADAT and a new box (Behringer ADA8200 or Saffire or MOTU)
2) Use the AES Port2 on my PCIe
3) Use the OMNI Expension Port and DigiLink
That other interface cannot be another Omni - yes I can see that in my HD OMNI GUIDE version 8.1 on page 18
Please advice...
Avid OMNI PCIe
Old 02-02-2014, 07:49 AM
It is not clear what you mean by 'best', as asked it is impossible to answer your question. You need to decide. For many people 'best' may be a lot about the pre-amp quality if you want a pre-amp, but it is not clear at all if you are asking about pre-amps. You are talking about analog-in, is that line in or mic-in or instrument-in? Do you already own enough analog mic preamps? 'Best' in terms of future expansion, guaranteed compatibility with Pro Tools etc, would likely be a HD I/O 8x8x8 box or similar. 'Best' as just high-end conversion might be a Prism Sound box and a bank loan. 'Best' as in cheapest with no regard to audio quality would be a anything made by Berringer. Other ADAT options should be much better.
It is also totally unclear what you mean by "AES Port 2 on my PCIe" ...... on your PCIe what? The HD Native PCIe card (the only PCIe card you have mentioned) does not have a AES/EBU port, it has two Digilink mini ports. You can connect another Digilink interface to either the expansion port on the Omni or the second port on the PCIe card. If you have a separate PCIe card which does have multiple AES/EBU "ports" (like a Lynx16 say) then you cannot use it in conjunction with any Digilink interfaces as there is no way to aggregate those interfaces.
Old 02-02-2014, 08:15 AM
Tim R. Tim R. is offline
I opted for my Rosetta 800 with an X-HD card connected along with the OMNI. When tracking even larger sessions I use my old 96 I/O with the Rosetta on the ADAT port of the 96 I/O.
The OMNI is what it is.
Tim Reisig
Main System: Pro Tools Ultimate 23.12, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 22.20, Apogee Rosetta 800 w/XHD card, Avid 96 I/O
Mac OS 13.2.1, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 23.9 (no Hardware), Mac OS 13.2.1, MBP (Macbook Air M2, 2022 24Gig Ram)
Old 02-03-2014, 06:46 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Or:
PCIe port #2 (32 ch per port) >X-HD card>XHD-expansion port >96I/O add sync cable
Old 02-06-2014, 02:51 AM
mmk mmk is offline
Originally Posted by propower View Post
Sure-
that would be nice wow i have the omni didnt realize you could do that...
great idea...
Old 02-07-2014, 05:11 AM
...but if you connect a low-budget Behringer ADA8200
Should OMNI be the master-clock or ?
If the OMNI is the master-clock I guess the connection will be:
OMNI ADAT OUT ---> ADA8200 ADAT IN
OMNI ADAT IN <--- ADA8200 ADAT OUT
Correct ?
|_| Yes
|_| No
Avid OMNI PCIe
Old 02-28-2014, 07:34 PM
Originally Posted by 68Tele View Post
So does connecting a 192 I/O or an Avid I/O to the expansion port of the OMNI give you more than 8 simultaneous inputs for recording?
OR...
Is the OMNI strictly limited to 8 inputs at one time no matter what?
Connecting another Digilink/TDM IO like a HD IO gives you all that IO, that is all separate from the Omni IO itself.
Darryl
confused about omni inputs! PT user Pro Tools HDX & HD Native Systems (Mac) 12 05-12-2014 07:50 AM
Trim Optical Inputs on OMNI? dwaynedelario Pro Tools HDX & HD Native Systems (Mac) 13 03-13-2013 01:34 PM
HD Omni inputs vin7 Pro Tools HDX & HD Native Systems (Win) 4 03-04-2013 08:36 PM
HD OMNi + 8 pre Adat how many inputs? Claudioska Pro Tools HDX & HD Native Systems (Mac) 6 02-18-2013 08:12 AM
OMNI question - # of inputs ianmiller Pro Tools HDX & HD Native Systems (Mac) 2 12-27-2011 07:34 PM
