Old 09-14-2015, 05:19 AM
Phantobias Phantobias is offline
Default Pro Tools 12 crashes and crashes...
Hallo there!
I'm a very new user to pro tools in general and now recently purchased the pro tools 12 version. I'm running it on a macbook mid 2012 i5, 8gb Ram and 250gb SSD with a focusrite scarlett 2i2. I never had any problems with my system, but pro tools really crashes from every hour to every few minutes...
I absolutely don't have a clue why and it really makes the software almost unusable, as you have to quick save after every move...
Any suggestions here?
Old 09-14-2015, 05:45 AM
jchan jchan is offline
Default Re: Pro Tools 12 crashes and crashes...
Unfortunately it sounds like a common issue with PT12 as I moved back to PT11 myself because of unusable behavior of PT12. But checking 3rd party plug-ins (A.I.R plugins are not stable from my experience) and updated interface drivers for the scarlet might make PT12 less prone to crashes. But no doubt PT12 needs some serious bug fixing to be done by pro programmers in the audio field..
Old 09-14-2015, 05:52 AM
Well I actually use almost only Slate Digital plug-ins. Also tried to reinstall and this preference delete thing. Nothing. This is a real pity because I tried Cubase und Logic in the last few years and must say after a few weeks that I love the freedom and workflow pro tools gives you.
But it would not be possible to use it in professional way right now, 'cause it could crash every second while recording...
Old 09-14-2015, 06:01 AM
jarrydee jarrydee is offline
I just upgraded from 11 to 12.2 a few days ago, installed right over 11...no crashes at all. I use all the slate plugins no problem...still have the VCA error when opening a session with VCA's on it, but after the session opens, everything still works the way it should. I am on Yosemite 10.10.5 if that matters
Old 09-14-2015, 06:19 AM
P_J P_J is offline
Waves Diamond (edit), Izotope Rx Post Production Suite, AIR, Auto Align, Arc2, Phoenix Surround, Anymix in use. Not a single crash yet with PT12 and I've been working long days.
I know this isn't helping OP and Avid must find a way to get all systems solid. But there are working combinations.
Old 09-14-2015, 08:16 AM
ronwasserman's Avatar
ronwasserman ronwasserman is offline
Hope this helps you. I've noticed a pattern going on. Seems like Mac users with 8GB of ram are having a lot of problems with 12.2. I think that could be one of or THE issue.
Ron Wasserman
http://www.ronw.com
http://www.imdb.me/ronwasserman
http://www.fishertheband.com
Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version.
Old 09-14-2015, 10:10 AM
gnjlee gnjlee is offline
I have a 2011 MBP with a 2.3 ghz proc, and 8 gigs of ram. PT Vanilla 12.2 is stable on Yosemite 10.4.4 for me, recording and mixing. Oh and I have lots of Waves and Izotope plugs loaded in my sessions.
Old 09-14-2015, 11:01 AM
Hmm. well the problem gets worse the more plug ins I use. But on the other hand my system usage never get's over 50%, so it's not in a range where you should have that much problems...
Old 09-14-2015, 11:05 AM
soybalm soybalm is offline
I only know that some Focusrite products suck on Windows and Protools with what seems to be a patched bloated driver. I know it's plugNplay on a mac. With an i5 and 8 gigs, I would increase the buffer at least. Shut off WiFi, Bluetooth. I'm cranking away on 12.2 with a Mac Mini late 2012 with an i7, and 16 gigs of ram. I'm using Maverick.
Dave Cournoyer-guitarist-project studio
Mac Mini late 2012, i7, Sierra
16GB PT10.3.10HD PT12.5.2
Apogee Mini-Me firewire.
Old 09-14-2015, 11:14 AM
mixer mixer is offline
12.2 unusable in my system.. mac mini i7 quad with 16 gigs and UA Apollo.
CPU never goes above 25% then all of a sudden spikes.. with an aae cpu error when bouncing. Really not usable.. My computer came with 10.10.4 so can't go back to Mavericks.. as of now I am going to try 11..
www.garyvandy.com
PT crashes with GRM Tools WQuintus AAX Plug-ins 12 05-04-2015 08:34 AM
PT Crashes and crashes again... Help needed! heabow macOS 5 01-23-2015 02:44 AM
Pro Tools Crashes Caatalyst Windows 28 06-17-2013 08:47 PM
Pro Tools 10.2 crashes again, and again... alfaholic macOS 7 07-04-2012 08:38 PM
Pro tools crashes mduroch1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-06-2011 04:05 PM
