#21
Re: AJA Kona LHI does not work with Protools
Not ideal, but you could remux (convert) videos you receive to the compatible frame rates in order to get your work done. With a 2-pop in the right place it won’t have an impact on your delivered audio media.
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn |
#22
I am not sure I am understanding this...
You had a BM Intensity Pro that played what you needed? Why did you buy the Aja card? Is the card referenced to Tri-Level? Do you have a tri-level generator? Does it do 25 and 24? Are you able to play 25 and 24 out these video monitors? From what you wrote, I am not certain that it is NOT the monitor. You checked tech specs of monitor and it WILL play those frame rates and formats? I have an LHi, but I don't use the HDMI.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
#23
This is very odd. I’ve been using an LHi for ages playing 25 and 24 fps on a Panasonic projector and various TVs with absolutely no problems at all. What did Aja say about the flash needing reprogramming? What settings have you got in Aja control panel?
Pete |
#24
Aja told i could to ignore the flash warning. It doest not show the right thing.
I had this bmd intensity card in use since pt10 where it worked perfect with protools. I jumped end of 2016 to pt 12 but was never satisfied with the video performance. I bought then this aja card because of my struggles with sync drift, jumped frames ........ as i wanted to change the cards then there came a new pt version( 12.7 or so) and bmd worked with driver version 10.4.3. Some jumped frames here and there but i could work very well with it Now with pt2018 ( i need it because of VR reasons) the jumping of frames during the first 3 seconds makes it nearly impossible to work with bmd card I tried ALL driver versions up to the newest one. So i wanted to give aja a try to see if things get better. Aja woks perfect with 29,97. tested with syncheck there is no drift and a stable constant sync. But unfortunately not in 25 frames and its the same cable and same monitor i use for years now. The card has no sync and runs in free Mode I think the card has problem eating 25 framess files. Why has protools such play problems as soon i load 25 frames project? Ale
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1) 1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+ |
#25
Something must be up with the card or your monitor. I was working perfectly with 25fps today, all day (and in the weeks leading up to today).
#26
because of this thread, I just bought the Kona KHi. It's working great. i got it for 75 bucks. I took off the fan, it's seems to be working fine. I'm going to burn it in over night to make sure it doesn't over heat without the fan. I will say the DCP on my black magic was out of control high. The aja driver seems to almost not register. So thats great for real time audio.
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
#27
Michael Goorevich Sound Designer / mixer www.goorevich.com PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3 MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24 |
#28
Well, I can confirm that I am unable to get 23.976 video to play on my HDMI monitor from the Kona LHI, even when going out SDI and running through an SDI-to-HDMI converter, no matter the settings in PT or in the AJA control panel. I have an ADR session tomorrow and was sent 23.976 video. Had to convert it to 29.97 to get it onto the talent's monitor. Baffling.
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7 |
#29
I have an AJA IO XT (kona 3G in a thunderbolt box) which I have had since they came out (I bought my review product).
Plays 23.976, 25, 29.97 1080 out of its HDMI (to my main screen) and SDI (to my booth via BM SDI to HDMI convertor) and SD to producer TV (not 23.976 as it doesn't exist) all day long without so much as a burp or hiccup.
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
#30
I'm sitting here now looking at a 23.98 vid out the LHi. What am I missing?
video out: aja kona or BM decklink | nucelar | Post - Surround - Video | 8 | 12-25-2017 02:36 PM |
Aja Kona LHe? | kkfaudio | Post - Surround - Video | 1 | 04-09-2016 07:12 PM |
AJA Kona IO XT supported with PT 10.3.6 ?? | vudoo | Pro Tools 10 | 1 | 07-23-2013 09:46 PM |
anyone tried PT 8 HD and Kona LS | vudoo | Post - Surround - Video | 0 | 02-10-2009 11:25 AM |
PT HD, FCP, and AJA/Kona | Chris Erlon | Post - Surround - Video | 2 | 05-17-2005 10:02 AM |
