Bounce to Disk / Upsampling?
I want to bounce a session to disk and then process the resulting wav file via Audacity (because my old version of Pro Tools can't increase tempo without changing pitch - also I'm using Audacity's Amplify plug-in). To ensure that Audacity processes with the fewest artifacts, should I
- bounce the project at the same bitrate/sample rate as the session, or - bounce at a higher sample rate (e.g. 88.2 for a 44.1 session), or - other suggestion? I'm wondering if upsampling would make things better - or possibly make them worse. Thanks, Mike
003 Factory PT LE 7.4 Intel Core 2 CPU 6320 @ 1.86GHz Gigabyte Technology G33M-S2H 2GB DDR2-SDRAM XP Home 5.01.2600 (Service Pack 2) |
Re: Bounce to Disk / Upsampling?
You may be in uncharted territory with this one. I would probably do both and see if either sounds better(or worse).
Anybody?
PT12 on Windows 7 Pro- no multiple bounce source tracks in Bounce To Disk window? | js_nyc | Pro Tools 12 | 6 | 04-21-2016 03:37 PM |
Bounce to Disk: Bounce to disk length is longer than my track on my time | dijitalhorse | Pro Tools M-Powered (Mac) | 1 | 02-23-2016 06:27 AM |
Bounce to Disk issues and bounce to direct show error. | SeattleHank | Windows | 7 | 01-01-2014 12:41 PM |
Bounce to Disk intermittently causes freeze and disk unmount after PT 10.2 Upgrade | AllThingsMusicStudio | macOS | 0 | 06-28-2012 07:16 PM |
could not complete the bounce to disk command because: a disk is full -34 help? | Henrydm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 17 | 03-27-2010 09:07 AM |
