Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 01-03-2018, 07:38 AM
drooster drooster is offline
Default MBox Pro 3 + 2017 iMac + Thunderbolt->Firewire adapters + latest drivers = success
I upgraded my computer to a new late-2017 27" iMac and spent a ridiculous amount of time trying to get my MBox Pro 3 to work on it, and was actually successful, so thought I would share what I did since I haven't seen any other threads on this:
1. Bought a new 2017 iMac that came with High Sierra (10.13.2) installed and no firewire ports
2. Used the following adapters to connect to the MBox Pro: iMac->Thunderbolt 3 to Thunderbolt 2 adapter->Thunderbolt 2 to Firewire 800 adapter->Firewire 800 to Firewire 400 adapter->Firewire 400 cable to MBox pro (side note: I still can't believe this worked)
3. Installed latest MBox Pro 3 drivers (1.3.5)
At this point nothing worked, the MBox control panel said "Hardware not connected", etc. So here's what I did:
4. Ran System Profiler (Apple Menu->About this Mac->System Report)
5. Looked under "Thunderbolt" and verified that the Thunderbolt 2 to Firewire 800 adapter was present
6. Looked under "Firewire" and verified that the MBox Pro is present. When I first looked under "Firewire", it showed "unknown device", so I reinstalled the driver and power cycled the MBox Pro 3, and then it showed up as an MBox Pro.
At this point the device showed up in System Profiler but the MBox control panel and Pro Tools still couldn't recognize it, until:
7. Opened Control Panel->Security and Privacy, saw the message "System software from developer 'Digidesign' was blocked from loading", and clicked on the "Allow" button.
After all of this, everything worked. Apparently there is a new "feature" in Mac OS 10.13.2 that requires a user's approval before installing 3rd party drivers, and for whatever reason the MBox Pro driver installer did not prompt me for for approval. Hope this helps someone.
Old 01-03-2018, 12:46 PM
Balanced Jack Balanced Jack is offline
Default Re: MBox Pro 3 + 2017 iMac + Thunderbolt->Firewire adapters + latest drivers = succes
Old 01-03-2018, 02:38 PM
We need a troubleshooting award for your diligence
Old 08-12-2018, 01:54 PM
Intini Intini is offline
This is great! I just bought an iMac 5k 2017 and will have to do the same! Thank you so much!
Do you know of any Thunderbolt 3 dock that has a firewire port so we could connect the MBP3 straight on it?
Apple ethernet adapters Thunderbolt vs USB tams Artist Series 1 05-04-2015 04:25 AM
Digi 003 via Thunderbolt on latest iMac SP4C3M4N FireWire & USB Audio Interfaces (Mac) 2 08-12-2013 02:24 AM
Mbox 2 Pro, iMac Thunderbolt and PT10 compatibility Maars macOS 15 05-06-2013 02:52 PM
firewire connection (adapters?) for MBox pro 3rd generation bscism Tips & Tricks 2 02-17-2012 01:07 AM
MBox 2 Pro with the latest iMac cougarman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-03-2007 05:55 PM
