Old 10-20-2011, 08:43 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: Why PT10 is not 64 bit... let's get this over with ;)
Originally Posted by Dism View Post
Once RTAS and TDM are phased out, AAX will be the only format and it will be 64 bit. It will allow for an entire recode of Pro Tools from the ground up, and give us a lighter weight platform with more of the features we expect.
Exactly the reason I'll be passing on PT10 and waiting...for as long as it takes.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 10-20-2011, 08:44 PM
Intransit Intransit is offline
Originally Posted by Violet View Post
Hasn't it already been years?
Let me rephrase: Years on top of years
iMac Retina 5K, 2020, 3.6 GHz 10-Core Intel Core i9, RAM 72GB
HD Native PCIe card /// OWC Mercury Helios 3S
PT 24.3.0
Old 10-20-2011, 09:55 PM
mykhal c's Avatar
mykhal c mykhal c is offline
Really? Other DAW's have had this stuff for YEARS, and they were still 32 bit. They're now 64 bit, and PT is still stuck in 32 bit land.
Otherwise, the new features look impressive.
Because it's the "Real Time AudioSuite" and "Time Division Multiplexing" that keeps it from being 64 bit and from allowing offline rendering.
Pro Tools is really the only host that supports two proprietary plugin formats, and now 10 has to host 3. Which means there would have to be a bridge for all 3 platforms. Instead, Pro Tools itself acts as the bridge. Once RTAS and TDM are phased out, AAX will be the only format and it will be 64 bit. It will allow for an entire recode of Pro Tools from the ground up, and give us a lighter weight platform with more of the features we expect.
well said!!! maybe not a total rewrite...but a memory management rewrite at a minimum...much like the new disk engine
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
Old 10-20-2011, 09:58 PM
Buddha Buddha is offline
Can't wait to hear 10 with HDX.
Old 10-20-2011, 10:22 PM
chrisdee's Avatar
chrisdee chrisdee is offline
So currently AAX is like RTAS/TDM 32bit aswell ?
Christian D Hagen | I7 Builds | PT/OS Compability Chart
Old 10-20-2011, 10:27 PM
chrisdee's Avatar
From sweetwater
With 32-bit floating-point bit-depth audio files, your audio won't dither down to 24-bit, a process that adds noise and reduces sound quality. This profoundly affects Pro Tools|HDX since audio will no longer dither down to 24-bit between plug-ins. The result: your audio will sound better than ever!
Does this dither thing apply for regular PT10 aswell ?
Meaning will the 32bit sound better than with 24 bit ?
Old 10-20-2011, 10:29 PM
Dism Dism is offline
Originally Posted by chrisdee View Post
From sweetwater
Yes.
32 bit float point is standard across all of PT10.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 10-20-2011, 10:32 PM
Technically, yes, because Pro Tools itself is 32 bit.
When the next version of Pro Tools comes out and drops RTAS/TDM support, we'll see 64 bit processing across the board.
D
Old 10-20-2011, 11:10 PM
huzzam huzzam is offline
32 bit audio??? I want 64 bit audio files! NOW!
ok Just kidding. BUT:
i don't see what 64/32 bit operation has to do with offline render/freeze. If it's RTAS/TDM that's in the way of offline rendering, I could buy that. But being a 32-bit program in itself would have nothing to do with it.
~peter in oakland
Old 10-20-2011, 11:13 PM
~peter in oakland
It's because both plugin formats are designed exclusively for real time processing. They have no rendering capabilities in their current incarnation.
RTAS and TDM are why Pro Tools is still 32 bit. You wouldn't be able to run a 64 bit Pro Tools with 32-bit float point math on 48 bit Time Division Multiplexing cards. Because of that, there's no point recoding TDM or RTAS for 64 bit (which would be required for a 64 bit Pro Tools version, unless you create a bridge, which could only add more problems).
AAX solves both problems at once.
D
Session share issue, PT10 Mac to PT10 express PC Big Mother macOS 0 04-16-2013 07:03 AM
PT10 HD system can't cope with session created in PT10 (LE) LizS Pro Tools 10 19 07-27-2012 03:46 PM
Bought PT10, do I remove the PT10 demo? esperanto macOS 2 04-18-2012 12:01 PM
PT10 help please , does PT10 really work on win 7 (digi support please) digi003 Windows 6 02-01-2012 06:36 PM
PT10 interop with PT9/8/7 -- Can PT10 force .ptf compatible audio? jeremiahmoore Post - Surround - Video 8 10-25-2011 08:55 PM
