Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
  #121
Old 06-29-2019, 10:29 AM
Default Re: 2018 MacMini experiment on ProTools HDX
Originally Posted by Markk View Post
Fully loaded Mac Mini with PT 2019 and this machine gets so hot with audiosuite that everything slows down due to kernel activity. Restart required and not appreciated. Any suggestions from the group here?
Is this related to this thread and HDX... if not please start your own new thread and try to provide the extra info, and answer to questions asked below there.
What exact model/EMC code and configuration?
What exact symptoms do you see before you restart? What exactly slows does?
What you are saying does not quite make sense. Heat does not cause kernel activity and then slow things down. Certain things Pro Tools or other software is doing may cause lots of CPU use, including high “kernel activity” and that may get things warm and then the CPU may thermal throttle.
How much kernel activity? when? Is it caused by specific things you are doing with specific plugins?
You need to try to work out what is going on.
You should exclude memory leaks in plugins... do you get out of memory warnings? What is your disk cache set to? What does the Mac activity monitor show is happening with total memory usage as Pro Tools is running up until you have to restart?
What troubleshooting have you tried? Start with Trashing prefs. Moving .aaxplugin files out of the plugin folder. Testing with other unrelated sessions or starting with empty sessions. Is the system optimized?
  #122
Old 07-14-2019, 01:45 PM
LDS LDS is offline
While in the topic - is anyone using HDX successful with a Sonnet TB3 enclosure? Sonnet still list it as incompatible, so I assume it still doesn’t work?
littledevilstudios.com.au
Pro Tools Ultimate 2019.6. OSX 10.14.6. HDX. Avid Omni. MacBook Pro 2018. 6 Core i7. 32Gb. 4x mSata SSD Drives + 4x HDD. Blackmagic Intensity PCIe. ATI RX580. Sync HD
  #123
Old 11-20-2019, 04:45 AM
Will Russell's Avatar
Will Russell Will Russell is offline
Good morning!
Reviving this thread. Anyone else have experiences to share having moved from a 5,1 12 core Cheese grater HDX system to a 2018 maxed out Mac Mini with the HDX card in a TB chassis?
Will Russell
Electric Wilburland Studio
www.wilburland.com
12 core 3.06Ghz MacPro, OS 10.14.5, PT2019.6, HDX, D-Command
Retina 5k iMac OS 10.14.5, PT2019.6, MBox3
Retina MacBook Pro OS 10.14.5, PT2019.6
  #124
Old 11-20-2019, 05:02 AM
audiobob's Avatar
audiobob audiobob is offline
Originally Posted by Will Russell View Post
Good morning!
Yes, working great here. TB3 is still unsupported by Avid and will cause problems. I'm using the Sonnet Echo Express but you'll have to buy a Sonnet Thunderbolt 2 card and use a Thuderbolt 3 to TB 2 adapter. Also using an OWC Thunderbay. All solid with one HDX card and a Black Magic Intensity Pro video card installed.
The machine does get pretty warm to the touch but I downloaded an app called Fanny to check my CPU temps and it's all within range. The hottest I've seen it was 68 degrees Celsius. Intel says the max temp for that processor is 100 Celsius, and I've seen no slowdowns whatsoever. Very fast machine and so far very pleased.
NOTE: Sonnet knows about the TB3 issue and they say Avid does as well and Avid is working on it. But I contacted Avid support and they say they have no timeline on TB3 support. Sonnet is giving $50 off the TB2 card for Avid users. Look here.
  #125
Old 01-04-2020, 09:54 AM
Markk Markk is offline
Hi folks!
We have found the Mac mini to run extremely hot (yes within the approved range) but it is unusual and slightly off Putting how hot it gets. Also, we do find the machine can easily get sluggish. This is a full maxed out Mac Mini. We have been testing one editorial suite but we have 10 stages that need to upgrade. So we are concerned. Any other pros out there getting good results with HD and Expansion with HDX and HD Native cards?
  #126
Old 01-04-2020, 12:33 PM
audiobob's Avatar
Hi folks!
Mine will get warm to the touch but never above 68 Celsius. The hottest that processor should run, from what I understand, is 100 Celsius so well within rage. Idle for hours it runs 41C. At average use it's around 58 to 61. I have not experienced sluggishness. It's been stable and very fast. HDX with Sonnet PICe expansion.
  #127
Old 01-05-2020, 09:05 AM
Thank you. I’m going to buy another to give it a shot. I have found that there are lemons sometimes when purchasing macs.
  #128
Old 01-05-2020, 10:49 AM
steins steins is offline
Hi folks!
We are running a maxed out Mac Mini with HDX-1 / Sonnet PCIe expansion chassis at work. I recently added a Sonnet eGPU chassis and a RX580 graphics card instead of using the built-in GPU, and I believe the Mac Mini runs both cooler and smoother now. I have no scientific evidence or numbers to back this up, it just feels smoother .
Stein Tore
Stein Tore Sønsteli
Studio at home: Pro Tools Ultimate 2019.10 (HDN), Mac Pro 5.1 OS X High Sierra, Avid I/O's, D-Command ES 8-fader.
Studio at work: Pro Tools Ultimate 2019.6 (HDX-1), Mac Mini 2018 OS X Mojave, RedNet/Dante I/O's, S6 24-fader.
  #129
Old 01-05-2020, 02:03 PM
khoop2112 khoop2112 is offline
I'm doing the same - the eGPU seems to make the redraw feel a bit smoother - running 2x4k displays, and 1 1080p monitor.
  #130
Old 01-05-2020, 02:13 PM
I ended up putting my Mini on a Laptop cooling pad just to help with ventilation. Not sure it makes much of a difference but can't hurt..
Which CPU / computer for protools 2018 boitason Pro Tools 12 19 11-13-2019 12:58 PM
ProTools 2018.4 won't launch planck Pro Tools 2018 6 08-27-2018 05:54 AM
S5 Fusion with ProTools 2018 tricklabot System 5 6 08-27-2018 02:48 AM
ProTools 2018.1 PTPerson ICON & C|24 4 02-19-2018 02:08 PM
I just tried a SRC experiment; dkrausz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-11-2002 07:59 AM
