Old 01-31-2018, 05:37 PM
estokes1958's Avatar
estokes1958 estokes1958 is offline
Default Clock issues with P12.8.3 and Scarlett 18i8
Setup: Win7 PC, Scarlett 18i8 (1st Gen), and PT12.8.3, typically running at 48kHz and 24b. New with PT12.8.3, dashboard shows "Sample rate" grayed out and equal to "48 KHz (Ext. Clock)". Never seen this greyed out, and never seen "Ext. Clock" spelled out.
Problem (new with 12.8.3): MIDI notes on instrument tracks play approximately half step flat. Not exactly half a step off. Does not matter which virtual instrument. No controller; notes entered thru MIDI editor. Possibly mismatch between sample rate and MIDI clock?
Solution might be to select the correct clock in "hardware setup", but Focusrite ASIO control panel does not provide this option. Workaround would be to adjust MIDI pitch, but it's not exactly half step flat.
Suggestions appreciated.
Ed
Old 01-31-2018, 05:56 PM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: Clock issues with P12.8.3 and Scarlett 18i8
Hi friend !
Do you have installed the Focusrite Scarlett Mix Control . Maybe there you can find the sample rate options there .
https://us.focusrite.com/downloads?p...18i8+first+gen
See page 31 of the scarlett 1818 first gen user guide :
- Jesus Alvarado -
Keep the volume UP !
Old 01-31-2018, 06:30 PM
Thanks Jesus. Yes, I am running Mixcontrol, and the sample rate is set at 48 kHz. But I understand that the sample rate and the MIDI clock are two different things. The MIDI clock is apparently slow, since the notes are flat.
Old 01-31-2018, 06:33 PM
jeam25's Avatar
Ok can you try resetting PT by deleting databases and preferences ?
Im running right now a Focusrite interface with PT18.1 and have no issues at all with midi .
- Jesus Alvarado -
Old 01-31-2018, 06:46 PM
Have tried this earlier, just tried again. Does not fix the problem.
Old 01-31-2018, 06:55 PM
jeam25's Avatar
Ok i understand . Is that session indeed at 24b - 48000hz ? Ctrl+2 shows that , let me know .
- Jesus Alvarado -
Old 01-31-2018, 07:38 PM
Yes 48k & 24b. Many sessions.
Old 02-01-2018, 11:05 AM
Top Jimmy's Avatar
A known issue with Scarlett interfaces on Windows is that you shouldn't use the Scarlett as your Windows audio device at the same time as using it via ASIO driver with pro software. If you are using the Scarlett as your Windows audio device, go into the Windows audio settings and change it back to the onboard audio device.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2019.10, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 02-01-2018, 11:37 AM
jeam25's Avatar
Good to know jimmy .
Didn't know for scarlett interfaces but with my clarett pre 8 x . I can do everything as in on mac os with it . I can work in PT , see youtube etc etc . Also while bouncing at 32 buffer i can stream , view videos etc . No stutter , no interruption . I tought it was the same for scarlett . Well my clarett is 2nd generation tough .
- Jesus Alvarado -
Old 02-01-2018, 01:51 PM
Thanks James. The Scarlett is my primary Windows audio device. I have never noticed any problems before PT 12.8, but I will try this and see what happens.
Ed
Interfacing Issue with Focusrite Scarlett 18i8 UberAubergine Pro Tools 11 2 06-04-2019 09:46 PM
Focusrite Scarlett 18i8 - High pitched, faster recorded issues Stef1342 Pro Tools 12 15 07-31-2017 01:53 PM
Crackles and Pops in PT 11.2.1 w/Scarlett 18i8 BassGuyGG Pro Tools 11 1 04-06-2017 12:18 PM
Scarlett 18i8, PT11 6101 error thecaptainandme Pro Tools 11 2 02-06-2014 04:20 PM
Focusrite Scarlett 18i8 kyluigi Third Party Interfaces 6 10-17-2013 09:14 AM
