Old 07-09-2015, 05:40 PM
mesaone mesaone is offline
Default Possible free and cross-platform alternative to Massey Talkback
Meldaproduction MUtility (in the free bundle) has two options that are of interest here, that were added in v8.1:
  • Silence when Playback is ON
  • Silence when Playback is OFF
I'm away from my rig right now, so I can't verify this... But the documentation implies that this operates as a transport-sensing cut switch.
So if you use it as the last insert on an AUX track set to your talkback or listenback mic, then enable Silence when Playback is ON, signal will only pass when the transport is stopped.
http://www.meldaproduction.com/plugi...hp?id=MUtility
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 07-09-2015, 05:42 PM
Meads Meads is online now
Default Re: Possible free and cross-platform alternative to Massey Talkback
Thanks, have to try that one out.
Right now I'm using a separate track with a test tone that triggers the sidechain of a compressor on the talkback aux.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 07-09-2015, 05:48 PM
Yeah, I did a setup like that which also had an automatic feedback safety mute thing... http://duc.avid.com/showpost.php?p=2097756&postcount=1
But it's a pain to set up, too many moving parts.
Old 07-09-2015, 05:51 PM
That's how I do it. I created a template and just import those two tracks in every recording session I do. But I agree, it's not that sexy. Having a plugin that does this would be a much cleaner thing.
Or even better - why isn't that a feature in PT? Wouldn't that be nice? There's so much cake to be taken for Avid, if they just implemented easy but really handy stuff like that.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 07-09-2015, 06:56 PM
Wall2Wall Wall2Wall is offline
I've heard a few folks talk about this one:
SOURCE-TALKBACK 1.2 FOR AAX WITH AUTO MODE
Enable console style talkback and listen-back without needing any external hardware. Newly designed for AAX 64-bit compatibility in Pro Tools 11. Now with Auto mode.
A. Talkback (Aux) goes on the Auxilary track that has your microphone input.
B. Talkback (Master) goes on your Master fader.
To open and close Talkback you have options:
1. Click the Talkback button to toggle
2. Toggle using then slash key "\". Latch using Shift+\.
3. Enable Auto-Mode in the Options menu. Talkback will close when the transport is running and open when stopped.
Old 07-09-2015, 07:15 PM
It is OSX only though.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 6800k
Win 10
Old 07-09-2015, 07:18 PM
Interesting. The only drawback I can think of (aside from OSX-only) is other plug-in windows "stealing focus" so the plug doesn't receive the \ key.
Unspoken benefit: MIDI translation utilities can read incoming MIDI note and CC messages to fire keystrokes or keystroke combinations. So you can use a footswitch, button, key, knob, fader, etc to control this plug-in. I've done something similar when using MIDI Ox with an arcade fightstick controller to fire samples in Reason
Old 07-09-2015, 08:56 PM
Shatzer Shatzer is offline
Here lately, I will have an audio track on the last fader of my artist mix. I'll have the input monitoring turned on, the output disabled (so it doesn't feedback in the monitors) and the headphone bus sent out post fader instead of pre fader like the other tracks. This way, I can just use the fader on my mix to turn talkback on/off. ALt +click will quickly bring the fader up to unity.
Old 07-09-2015, 09:04 PM
At that point, why not isolate the solo for that track in PT and use the ON button on that track of the Artist Mix as a latching talkback switch? Assuming you have this set as the last fader on your layout.
Old 07-10-2015, 12:42 AM
Top Jimmy's Avatar
It's not free but Blue Cat Audio's Plug'n Script ($99) has an Auto Talkback script available for it.
You can also program MIDI CC to control Blue Cat plugin parameters giving you the ability to bypass at will via controller.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2019.10, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
HTML code is On
working cross platform in HD, LE, and Free? Archmart Digidesign Hardware & Software 3 06-26-2004 01:18 PM
working cross platform in HD, LE, and Free? Archmart 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-23-2004 03:57 PM
working cross platform in HD, LE, and Free? Archmart Pro Tools TDM Systems (Mac) 1 06-23-2004 11:26 AM
Help: PT Free and cross platform? fcqmax Digidesign Hardware & Software 1 06-13-2003 01:14 AM
Cross Platform Mac/Win sglad Pro Tools TDM Systems (Win) 0 05-04-2001 10:08 AM
