Old 01-28-2013, 04:00 PM
kieran.mia kieran.mia is offline
Default H/W Buffer Error (pro tools error -6104) Only 1 audio track running.
Hi Guys,
This is my first time posting here, if anyone could be of assistance that would be fantastic!
I recently got myself a new system: 8 core Ivy Bridge i7, 16 GB ram running Mountain Lion. I use Pro Tools 9 and initially it wasn't able to run in mountain lion but I found out that people were able to make it run with the 9.0.6 update, so I did the update and got pro tools to run (Yay :'D)
I then imported a song into pro tools to test my I/O to see if I had audio coming through etc and a split second after I hit play i had the H/W Buffer Error (pro tools error -6104) window pop up. The msg said that I should reduce the amount of tracks and/or plug-ins that I was running, though I only had 1 audio track up with no plug-ins running. Now I don't by any means have an under powered system, and I tried reducing the amount of cores I was using, and I also reduced the max CPU usage down to 65%. Nothing changed. I'm absolutely stumped. If anyone could be of some assistance that would be amazing, this error is the bain of my existence at the moment ):
Old 01-29-2013, 02:39 AM
crizdee's Avatar
crizdee crizdee is online now
Default Re: H/W Buffer Error (pro tools error -6104) Only 1 audio track running.
Originally Posted by kieran.mia View Post
Hi Guys,
What interface are you using?
What's the hardware buffer set to?
Have you set it to use 7 cores in the playback engine?
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Pro Tools 11 - CPU usage holding off USB Audio Error -6104 gregoryl Pro Tools 11 144 01-25-2020 10:49 PM
Pro Tools Error (-6104), CPU usage is holding off USB audio xstortionist macOS 13 10-17-2012 11:51 AM
CPU Usage Holding off USB Audio -6104 error Mark Mangini 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-11-2010 08:05 AM
USB Audio...HW Buffer Size error 6104 problem? dewald 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-15-2008 11:21 AM
cpu usage error with single track eror -6104 Rowdyb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-24-2007 09:34 AM
