Old 11-20-2011, 05:36 PM
EricMulhern EricMulhern is offline
Default Pro Tools 9 Playback Error Lead to DAE Error 743 Which Lead to A CPU Overload Error
Hi, I'm having some ridiculous and really annoying problems with Pro Tools. I am on an iMac with Snow Leopard Version 10.6.7, with 3.2 GHz Intel Core i3 and 4 GB 1333 MHz DDR3 Memory. I have Pro Tools 9.02, although I qualify for a free upgrade for Pro Tools 10 (I haven't upgraded yet because there's a good chance that there will be compatibility issues). I have an Mbox 2 Mini.
First, I opened up Pro Tools to find that there was no audio during playback. It might have done this because I had recently opened a different project that I had started on a different computer, but I'm pretty sure I've opened this project since then. I screwed around in the Setup menu, mainly in Setup>Hardware but all I managed to do was turn the tracks gray and still not have any sound. After a crash and trying to restart Pro Tools several times, I managed to get rid of the grey tracks, but also to get the DAE error 743. I screwed around in the Setup>hardware menu some more, and got the error to go away, only to have it lag so much that it can't even play (and the playback automatically stops right after I hit play), and it occasionally gives me the message: A CPU overload error occured If this happens often, try increasing the "H/W Buffer Size" in the Playback Engine Dialog, or removing some plug-ins. (-6101). The H/W Buffer size was already at the max, and I tried removing all my plug-ins, but nothing changed.
Can you help me get this Bug-Infested program working again?
Old 11-20-2011, 06:39 PM
Default Re: Pro Tools 9 Playback Error Lead to DAE Error 743 Which Lead to A CPU Overload Err
Actually nevermind, I screwed around in the Setup>Hardware menu some more and the problems went away
HELP!!! "A CPU OVERLOAD ERROR" Everytime I track or playback EngineeringTheEnemy Pro Tools M-Powered (Mac) 3 12-04-2011 11:28 PM
Error 9073 and Error Increase/Reduce H/W Size during playback Digi001 Karma180 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-05-2011 08:46 PM
CPM Overload Error 6101 on Pro Tools LE v8 cmcclean 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-25-2011 09:32 PM
Pro Tools 8 and Nord Lead 2x reycantong 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-18-2009 07:22 AM
LEAD IN or LEAD OUT error when finishing BAKs Alécio Costa Pro Tools TDM Systems (Mac) 1 02-22-2002 09:25 PM
