Old 02-14-2010, 04:20 PM
Zoduati Zoduati is offline
Default PT LE 8 & Older Sessions (6.4)
I have migrated and updated my ProTools LE system from Windows to Mac, and from version 6.4 to version 8.03.
I hope to continue working on existing projects (created with 6.4). Having copied the files over to my new work drive, Is it recommended to simply open the old file in v8.03, or should I do an "Import > Session Data"?
Thanks,
Geoff
Old 02-14-2010, 05:05 PM
paulreed paulreed is offline
Default Re: PT LE 8 & Older Sessions (6.4)
try opening the sessions normally (when you are alone) and see what happens, if it crashes, try the import session data trick. When I updated to version 8, I had to use import session or all my sessions crashed...on pc.
Old 02-14-2010, 05:13 PM
Thanks. I have tried opening the old files with varying levels of success... some had problems finding the audio files.. I haven't yet tried the import data.
Cheers
Geoff
Old 02-14-2010, 05:16 PM
If a session does not open, try holding the SHIFT key while you try again. This will disable all the plugins(maybe you have some that need updating). Once you get a session open and audio files showing up, save it in the newer format(pts vs ptf).
Old 02-14-2010, 05:22 PM
THANKS for the tip, very helpful.
Geoff
can't open older PT sessions...help! js1268 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-24-2010 06:33 PM
updating older sessions? Marvin the android 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-06-2009 10:24 AM
Older PT Sessions Jeffrey Talbot Pro Tools TDM Systems (Mac) 8 08-10-2005 02:56 PM
PTLE 6.7 and older PT sessions lwilliam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-30-2005 11:24 PM
Older PT sessions bopsi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-02-2003 02:47 AM
