-6088 and -6085 errors, any ideas?
Hi I just got the Creation Station Rack HD and am trying to run a 003 and Pro Tools 7.4cs7. The key word is trying because I get errors -6088, the operating system held off interrupts for too lond...try increasing the "H/W Buffer Size" and error -6085, the audio device buffer underflowed...try decreasing the "H/W Buffer Size". This can happen in any size session. And I think has to do with moving the Edit Window in anyway, scrolling, zooming, etc. but not sure. I have already tried trashing prefs and databases, and installed a couple windows hotfixes. Do you guys have any other ideas?
SiSoftware Sandra System Host Name : CSRACKHD User : Audio User Workgroup : MSHOME Processor Model : Intel(R) Core(TM)2 Quad CPU Q9300 @ 2.50GHz Speed : 2.50GHz Performance Rating : PR17000 (estimated) Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Internal Data Cache : 4x 32kB Synchronous, Write-Thru, 8-way set, 64 byte line size L2 On-board Cache : 2x 3MB ECC Synchronous, ATC, 12-way set, 64 byte line size, 2 threads sharing Mainboard Bus(es) : ISA PCI PCIe IMB USB FireWire/1394 i2c/SMBus MP Support : 1 Processor(s) MP APIC : Yes System BIOS : American Megatrends Inc. 8.12 System : System manufacturer System Product Name Mainboard : ASUSTeK Computer INC. P5BV-C Total Memory : 3.2GB Chipset 1 Model : ASUSTeK Computer Inc ??? (29F0) Front Side Bus Speed : 4x 357MHz (1428MHz data rate) Video System Desktop Monitors/Panels : 2 Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Monitor/Panel : Plug and Play Monitor Monitor/Panel : Plug and Play Monitor Adapter : NVIDIA GeForce 8600 GT Physical Storage Devices Hard Disk : ST3500320AS (466GB) Hard Disk : ST3500320AS (466GB) Hard Disk : ST3500320AS (466GB) CD-ROM/DVD : ATAPI DVD A DH20A4H (CD 48X Rd, 48X Wr) (DVD 6X Rd, 6X Wr) Logical Storage Devices WinXP (C:) : 462GB (439GB, 95% Free Space) (NTFS) Hard Disk (D:) : N/A Library (E:) : 466GB (322GB, 69% Free Space) (NTFS) CD-ROM/DVD (F:) : N/A Removable Drive (H:) : 1.9GB (1.1GB, 59% Free Space) (FAT) Peripherals USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8 USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9 USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : Generic USB Hub USB Controller/Hub : Generic USB Hub USB Controller/Hub : USB Mass Storage Device FireWire/1394 Controller/Hub : Texas Instruments OHCI Compliant IEEE 1394 Host Controller Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : Microsoft PS/2 Mouse Printers and Faxes Model : Microsoft XPS Document Writer Power Management AC Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP/2002 Professional 5.01.2600 (Service Pack 2) Network Services Network Drivers Enabled : No |
Re: -6088 and -6085 errors, any ideas?
Have you turned off all un-needed stuff with XP.
I found by running msconfig, and Un-Checking: Load System Service and Load Startup Items My Old P4 runs solid with 003 Rack PTLE 7.4 I first tried selectively turning off stuff in msconfig, start-up..but I haven't figured out yet exactly what keeps "bumping" PT to give the "under or overrun buffer" messages, but with everything off it is quite stable. Good luck. |
thanks for the idea but no luck
Are you recording to the system drive?
No I am using the second of three 500gb hard drives and I should add that it occurs during playback as well
new update: I have tried replacing the firewire card with another one on my old rig that worked smoothly. So maybe is it a mother board issue? I have an ASUS P5BV-C thanks ahead of time
Have you done all the steps in the General Troubleshooting thread yet? And, if so, which ones have you done specifically?
I have disabled device drivers, disabled system startup items and services, deleted the DAE and Pro Tools perfs files, I have the newest version of the CS, and have disconnected all extra USB or F/W devices, I am going to try the rest of the list and report back, in the meantime any suggestions?
Disabling wireless devices, built in sound cards and network cards - basically everything that's covered in the General Troubleshooting thread.
6085 is usually related to an unsupported chipset on the firewire controller card. Yours appears to have a TI chipset, which should work fine. Most likely it's something going on in the background interfering with proper communication. |
Well now I have officially done everything in general trouble shooting up to and including the hotfixes and have still not solved the problem, I have tried using a PCI F/W card that worked on my old rig, and still getting the errors. I dont know what to try next, could it be a video card problem?
6085 and 6088 Errors - Just Started - Sandra Report Included | JCWarrior | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 11-03-2010 02:13 AM |
Trouble in 002 Land: 1394 intermittent, --6088, -6085 errors | dbrunell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 01-04-2010 09:33 AM |
6088 and 6085 errors FIXED | Kirby B. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-14-2008 11:49 AM |
-6085 / -6088 errors caused by bad video monitor | daeron80 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-10-2007 09:02 PM |
Digi 002: Errors -6085 and -6088 | zail | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-04-2006 10:02 AM |
