Old 05-20-2008, 07:01 PM
skyking skyking is offline
Default Help with Bouncing to Disk Please
i never bounced to disk because i always sent my songs to an Alesis Masterlink and burned them to disk from there.....now im trying to make a Master cd using bounce to disk and i dont have a clue what im doing.....can someone explain the process such as do i select wav or aiff or mp3....and any other other settings too.....i made a cd using wav but the cd would not play on 2 different cd players...but if someone can explain the process to make a master cd using bounce to disk id appreciatte it......thanks chas
Digi 002 on windows xp pro .. pentium 4 @ 1.6 ghz....intel 845 chip...gigabyte p4 titan MB....seagate hd.....40 and 120 gb @7200....1 gig of ram
Old 05-20-2008, 07:36 PM
Default Re: Help with Bouncing to Disk Please
i found an article that shows bouncing to disk using wav format but as i said when i burned a cd using wav format it would not play on 2 different cd players....anyone have a clue what i might be doing wrong?
Old 05-20-2008, 08:43 PM
You need to bounce to 16 bit/44.1K stereo interleaved to make an audio CD. If you session is done at 24 bit, you also need to insert a dither plugin on a master fader(in the last slot) and dither to 16 bit.
Old 05-21-2008, 03:41 PM
Kirby B. Kirby B. is offline
With newer version of Nero and some other programs, one does not need to bounce to 16 bit anymore. 44.1K stereo interleaved, yes- I make audio CDs out of the 24 bit bounces. Am I missing something here? Do I need to dither down (and to 16 bits) for quality of sound?
Digi002R PT2018 Win 10
INTEL Core i7 930, 3.52 Ghz
GIGABYTE GA-X58A-UD3R
CORSAIR XMS3 12GB 1600Mhz
2 X WD 1TB Caviar Black 64 GB cache
MOTU Traveller PT2018
MacBook Pro Mojave
16GB DDR3
Old 05-21-2008, 03:55 PM
spkguitar's Avatar
All CDs that play on normal CD players are 44.1kHz/16bit, no matter what. If the newest version of Nero accepts 24bit files for CD creation, then it is automatically dithering (and probably not in the best way possible).
Old 05-22-2008, 06:15 AM
Yes, I knew that all CDs that are normal are 16 bit, but I didn't know that a writing program would dither the 24 bit input. It seems obvious now . Will go back to 16 bits for burning.. I only tried the 24 bit versions for a few quick listen things, which is a good thing....
MacBook Pro Mojave
16GB DDR3
Bouncing to Disk Noobish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 05-15-2011 02:29 PM
Bouncing in session first vs. bouncing straight to disk... WATYF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-07-2007 04:17 PM
bouncing to disk udo4accept Tips & Tricks 8 04-24-2005 08:22 AM
Bouncing to Disk sh336697 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-24-2004 01:46 PM
Bouncing To Disk brianpatrick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-26-2003 08:28 PM
