Old 02-12-2007, 02:37 PM
mondoJML mondoJML is offline
Default LCD Monitor Arms
Just wondering if anyone had a recommendation on a good LCD monitor arm for a 20 inch WS monitor. We are getting a D-Command and positioning the monitor will require it to be floating on an arm. We also need it to be able to tilt pretty far, at least 45 degrees.
Any help would be appreciated.
Old 02-12-2007, 03:49 PM
5Moes 5Moes is offline
Default Re: LCD Monitor Arms
Check out the monitor arms made by Innovative Office Products. I have the Arcview dual-monitor arm, and it does a beautiful job of supporting my dual 19" LCDs. Once you get the gas shocks dialed in, just a light touch is required to reposition the monitors. It includes all hardware necessary to mount the base in a variety of ways. Not cheap, but well built.
Arcview Dual Monitor Arm
Old 02-12-2007, 03:58 PM
Craig Henighan Craig Henighan is offline
Mondo, check http://www.ergoindemand.com/lcd_mount_articulating.htm. I actually use 2 of these with my D Control. When I'm editing I wanted 2 monitors (20's). I went to the local hardware store and found some pipe that was the same diameter as the pipe Spacedec gives you for a single arm, only longer. I was then able to install 2 of the Spacedec monitor arms, and they can be adjusted to pretty extreme angles. The 2 20's take up alot of real estate for getting to the center section, but for me when cutting its fine, as I'm usually just reaching for faders. When I mix, I move the monitors back to get to the joy sticks and other features.
cheers
-craig
Old 02-13-2007, 09:32 AM
Perfect. Thanks guys. I'll check out all of those sources.
Old 02-13-2007, 11:21 AM
budster budster is offline
Hey there,
I also purchased a dual monitor articulating arm from innovative office products to float 2 19" LCD's above a Neve 8232 and it worked out great.
Buddy
Old 02-13-2007, 01:10 PM
Magnetic Magnetic is offline
Ergomart
We bought two of their arms, and I'm happy.
Old 02-22-2007, 01:10 AM
ryan de topanga ryan de topanga is offline
Got a Humanscale from RSPE in L.A. Very nice. Lots of options
http://www.humanscale.com/products/m...pport_main.cfm
Old 05-23-2007, 01:01 PM
CharlesL CharlesL is offline
how about triple monitors? I'm looking for one that allows forward/backwards, upwards/downwards as well as angle tilting.
Any good ones?
Thanks!
.. TWO ROOMS pte ltd
.. Audio Post Production
.. www.tworooms.com
Old 05-23-2007, 08:18 PM
Chief Technician's Avatar
Ergomart
I have one of their arms for a 20" studio display that I don't think I need anymore. Email me if you are interested.
Old 05-24-2007, 12:21 PM
Floater99 Floater99 is offline
Any good ones?
Thanks!
Maybe something from Chief like this?
Chief Manufacturing
- Floater99
HTML code is On
Selecting Instrument Track Auto Rec Arms Connor Pro Tools 11 1 07-26-2013 07:18 AM
Replacement monitor arms for D-Control Console quadraphonics Post - Surround - Video 0 01-10-2012 07:45 AM
Ergotron monitor arms WildHoney Pro Tools TDM Systems (Mac) 9 05-03-2009 03:57 AM
record track un-arms after stop! soundwavve Pro Tools TDM Systems (Mac) 3 07-30-2008 09:16 AM
Best LCD Monitor Arms Joe Mendelson Post - Surround - Video 3 02-19-2008 12:41 AM
