Old 02-28-2006, 10:54 AM
Freddie Rodriguez Freddie Rodriguez is offline
Default Mbox still sounds like loud wind
The MBox output sound like loud wind (or white noise) when I try to playback an audio file or video clip...
The spdif light and the USB light in the front of the box are on at the same time...
If I connect a headset in the front of the Mbox I also hear the noise...
If I play a video with Xpress DV Pro HD thru the Mbox which is how it’s normally connected, I hear the same problem but if I connect the speakers to the audio board on the computer the audio sounds OK...
I install Protools on my Laptop using Ver 6.7 with the same Mbox connected to it, it sound OK no problems, At least the Mbox is OK and the spdif light and the USB light in the front of the box are not on at the same time…
Something is corrupted in the software on my main computer... I haven’t found any info on the web site about a related problem.
PC intel board 3.0 processor - 3gig of ram Xpress Pro HD and Protools Ver. 7
Did not installed any new software or hardware
Things I’ve tried…
1. Reinstalled the drives.
2. Reinstalled Protools Ver 7.
3. Installed protools with the problem Mbox on laptop, and this is OK.
4. Disabled Mbox on the PC restarted the PC with out the Mbox… reconnected and had the PC install the drive from the Protools Ver. 6.9 Disk since the Ver. 7 is just in one file no drivers folder, reinstalled the driver it found, the driver says it’s an older version, installed it anyway.
---Problem did not go away..
Please help.
Freddie
Old 02-28-2006, 12:33 PM
Ducky Ducky is offline
Default Re: Mbox still sounds like loud wind
Make sure you don't touch anything while PT is booting up (or the computer for that matter).
Not sure if that will fix your problem, but with my MBox1, every time I did ANYTHING while PT was booting, I got some very strange sounds coming out of my monitors and had to reboot.
Old 02-28-2006, 04:11 PM
Musikguy Musikguy is offline
You have your input source set to S/DIF which changes your clock source to S/DIF. Go to setup and then choose Hardware. Change input from S/DIF to Analog and it should output correctly.
Structure FREE Sounds 114 - Wind Instruments RussUK Virtual Instruments 0 08-10-2009 03:33 PM
Loud click and pop when auditioning sounds CD Productions Pro Tools TDM Systems (Mac) 2 03-28-2006 12:41 PM
Mbox sounds like loud wind Freddie Rodriguez 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-28-2006 10:11 AM
Auditioning sounds in project browser loud!! Mark 66 Post - Surround - Video 0 07-22-2004 02:45 PM
Loud sounds in ProTools FREE abrice Digidesign Hardware & Software 1 04-05-2002 01:58 AM
