Old 12-31-2004, 11:29 AM
brianres brianres is offline
Default Oxford 912 Chipset
Hello, does anyone have any experience using this hard drive chipset with Pro Tools? If so, are there any compatability issues when using it with a Digi002 and a Powerbook G4 1.25 ghz? I am looking a buying a LaCie d2 Extreme 200GB Hard Drive and want to know if that is a reliable drive for use with Pro Tools. Any info would be much apprceiated.
Thanks
Old 12-31-2004, 10:52 PM
nic copenhagen nic copenhagen is offline
Default Re: Oxford 912 Chipset
I've been told that you have to you something with a 911 chipset for firewire drives.
I know many people that use the Lacie Drives with no problems.
Old 01-01-2005, 06:21 AM
OmniMedia OmniMedia is offline
hi
i had great results even on a 500 Big Disk Extreme FW800 which uses an Oxford 922
(digi won't recommend this, but believe me, I had great results)
I also have the newer FW800 250GB Drive extreme (Oxford 912) with great results as well
this is on Mix Down
I haven't tried on Recording
21 tracks at 96/24 on a PB 1.5 with 1.5 GB of RAM (OS 10.3.5)
(2) D-verbs (4) Focusrite Comps, (1) Mic Modeler and (1) L2 Limiter
it also helps to have your drives on a separate bus (Lacie PCMCIA Card)
hope this was helpful
Happy New Year's
regards,
CJ
Is Oxford 944 chipset okay with PT 9? shotgunndunn macOS 4 01-19-2012 07:24 PM
911 OXFORD CHIPSET ? HOW DO YOU KNOW? hectoru67 Pro Tools TDM Systems (Mac) 4 06-03-2006 06:48 PM
oxford 911 chipset--anybody?? stickstome2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-22-2006 02:21 PM
Is Oxford 911 Chipset Really Necessary 4 Ext HD? ShakaBrah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-01-2005 08:22 PM
Oxford 911 chipset tsampson Pro Tools TDM Systems (Mac) 0 06-18-2001 09:54 AM
