Old 11-23-2004, 02:43 AM
Evil Jack Evil Jack is offline
Default G5 firmware upgrade :recommendation
I can confirm that this update has solved the firewire issues on the G5 Dual 2.5Ghz .
I'm using one of these for my LE/002Rack rig, and before the update the rear port was unusable. (front port was better but still not 100%)
Both ports seem rock solid now
Direct Link Here
Old 11-23-2004, 09:48 AM
moebius_loop moebius_loop is offline
Default Re: G5 firmware upgrade :recommendation
Hi Evil Jack,
Specifically, what problems were you having that the firmware update solved ? Was it the digital / hissing noise issue ?
You can read about my MBox and G5 noise issue at the following link -
http://duc.digidesign.com/showflat.p...ev=#Post725687
Do you think the firmware update will help me ?
I am running a Dual 2.0 GHz G5 with 512 MB ram and OS X 10.3.4... What are your dual 2.5 GHz G5 system specs (OS version, RAM, etc...) ?
Thanks in advance.
Old 11-24-2004, 03:49 AM
Hi!
Dual 2.5 Ghz G5/512MB/OSX 10.3.6
I think the firmware update is only for recent RevB G5s (though I may be wrong).
As I said, my problems were specifically with firewire (poor connections to 002 - especially through rear port). Other users on this board have had the same issues. The upgrade also appears to solve loud fan issues for some...
Wasn't the digital/hissing noise to do with the PSU, which Apple were replacing (with a revised version) under warranty?
Good luck!
Old 11-24-2004, 11:48 AM
Well, I thought that it was ONLY a PSU issue too, but then I tried the MBox on 2 different friends Pentium 4 PC towers with quiet PSU's, as well as on another, 2nd generation, Dual G5 and the problem is there as well (although, admittedly, it is more present on my G5, which I will take up with AppleCare).
I have contacted Digi Tech Support via email with the whole story and have asked if I should get the MBox evaluated by an authorized service provider (there is one here in Montreal which I could bring it / send it to, depending on how these things work).
In the meantime, what do you think of this workaround:
I am thinking of borrowing a friend's mic preamp to feed signal to the MBox's input set to LINE, that way I will not have to crank the MBox's gain too near the last dot and, therefore, won't get this hissing...
Let me know...
Best regards !
Firmware upgrade on 003 with PT9 shobud Windows 3 05-06-2013 11:23 AM
Did somebody upgrade MC Mix firmware? Durcu Artist Series 2 02-15-2011 01:17 PM
Mac G5 Firmware Upgrade MidiMe Pro Tools TDM Systems (Mac) 5 01-03-2005 06:12 AM
6.4 firmware upgrade? henke b 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-20-2004 01:27 PM
002 r firmware upgrade ? ISedlacek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-23-2003 06:47 PM
