Old 03-29-2004, 07:08 PM
TDrey TDrey is offline
Default Crackling Noises // Digi 002
When I use my SPDIF and switch my DIGI 02 from 44.1 khz to 48 khz (24 bit) my left channel makes a crackling noise once I intraduce a signal -- Any one familure with this???
Old 03-29-2004, 07:21 PM
Chris Cavell Chris Cavell is offline
Default Re: Crackling Noises // Digi 002
Try increasing your hardware buffer size a notch and make sure that your clock is set to spdif.
Cavell Studios
Old 03-29-2004, 09:25 PM
lemix's Avatar
lemix lemix is offline
Yes, and just make sure the incoming digital signal is matching the session's sample rate !
Also, some devices ( like older DATs) stop transmitting clock, when playback stops.
cheers,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 03-29-2004, 09:37 PM
Aussie169 Aussie169 is offline
Yep, Sounds like sample rate missmatch to me
Old 03-30-2004, 02:53 PM
cubasteve cubasteve is offline
I have this problem with my AMII (don't laugh) card. Only at 48k and only when i use the spdif as an effects send (not when spdif mirroring is checked).
Digi acknowledged the problem, but ultimately never did anything about it. I'd assumed it was a flaw in the AMIII card, but if it's in the 002 as well, then i'm not sure what that means.
I think it may have to do with cpu timing and your mboard as well. I have an XP2000 on a KT133a chipset.
And this assumes we're having the same problem.
Cubasteve
Crackling Sound & other noises Porchass Windows 14 05-06-2013 12:58 AM
Crackling noises monitoring recording PT 8 latprod Pro Tools M-Powered (Win) 5 03-12-2010 01:25 PM
Crackling noises Hugovn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-09-2010 01:47 AM
odd crackling noises with iTunes???? danieljohn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-29-2005 12:19 AM
crackling and buzzing noises, poor track synch long otis lynch Digidesign Hardware & Software 0 01-29-2001 08:06 AM
