Go Back   Avid Pro Audio Community > Pro Mixing > Avid S6
Old 11-25-2019, 03:39 PM
DHS DHS is offline
Default S6 Talkback>MTRX>Source connect
I have my talkback running through the s6 Master module. Im assuming the output on the Master Module is just a thru because it sends the mic signal no matter if I have TB button engaged or not. So if I want to route a signal to source connect and be able to toggle that, whats the correct way of doing this.
I have the s6m40 with a goose neck mic and a single channel preamp for the mic. One way I could do this is just set up a Cue that busses to SC and mute it on the console. How can this work by just using the talkback button?
Old 11-25-2019, 05:08 PM
creativecontrol's Avatar
creativecontrol creativecontrol is online now
You can create multiple monitors within your DADman monitor profile, each of which can be triggered by the same TB mic, and each with distinct TB logic. You could, for example, create an additional monitor (separate from your primary control room) whose output is designated as a DigiLink output source which feeds into your PT template and is routed to the appropriate Source Connect destinations within said template.
Yes the connection on the MTM is simply an XLR pass-thru.
Jeff
Jeff Komar
how to listen in mono at a stereo source with DAD's MOM & Avid MTRX Johnny Hulst Pro Tools HDX & HD Native Systems (Mac) 2 07-01-2019 11:47 AM
changing sample rate or clock source on MTRX popping monitors jgaz Avid S6 9 04-16-2019 08:32 AM
Source Talkback AAX gets auto talkback MIKEROPHONICS Post - Surround - Video 0 11-20-2013 09:15 AM
Routing internal talkback mic to aux (source-connect) D'Animation ICON & C|24 2 10-06-2011 04:18 AM
Source ZIP- a new nifty utility from those Source Connect People MIKEROPHONICS Pro Tools TDM Systems (Mac) 0 01-13-2010 10:05 AM
