Old 09-21-2015, 03:14 AM
8-echos 8-echos is offline
Default Enable MIDI voicing
Hello.
Is it possible to enable MIDI voicing in a MIDI track?
I want to assign some notes to voice 1, some to voice 2, some to voice 3.
The reason for it is that the export in Sibelius is more efficient.
Any other solution is welcome.
Old 09-21-2015, 03:51 AM
Stig Eliassen's Avatar
Default Re: Enable MIDI voicing
I believe that Event (menu) > Event operations > Select/Split notes will do what you want?
Old 09-21-2015, 04:37 AM
It will but it will do it to separate tracks which is what the op would need to get different sounds for each set of notes.
There is a way to do it in one track if the notes are not in a chord and that is via patch changes where one wants the sounds to change. Trying to do patch changes inside a chord gets real messy and may not work right.
Old 09-21-2015, 10:52 PM
Exactly, I need separate "voices" inside of a MIDI track. I understand, only to move notes to another track is possible to get voicing.
Is it possible to select notes, and by a command move them to another track?
Old 09-21-2015, 11:19 PM
Check out the event operation I mentioned. You can split notes to new tracks based on a set pitch criteria.
Question about voicing... dtrusz Pro Tools TDM Systems (Mac) 4 06-05-2008 09:36 PM
PT6 AND AUTO VOICING QXR987 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-17-2003 12:22 AM
voicing Dr. J Tips & Tricks 3 08-23-2001 09:22 PM
Extra Midi Out to enable 32 midi channels marka123 MIDI 1 02-12-2001 08:54 AM
