Old 09-22-2010, 10:33 AM
idris idris is offline
Default Meters for room calibration
Is this meter up to the job for room calibration (for a basic sound editing suite, as opposed to a full dubbing theatre)?
http://www.maplin.co.uk/Module.aspx?ModuleNo=226470
The spec looks almost the same as those twice the price, but I don't know if the "almost" is what makes the difference.
PT2020.5.0 / HDN / HD Omni / MC Control / Intensity Pro / Catalina / 3.7 Quad core Intel Xeon ES (trashcan) MacPro / 12GB RAM
Over 30yrs experience in pro-audio - mostly for picture.
Old 09-22-2010, 11:23 AM
Postman Postman is offline
Default Re: Meters for room calibration
A big limitation is the meter's integration time, they call it "time weighting". It is spec'd as FAST. SLOW allows a much more steady reading when using fullband pink noise. Fast will probably be okay with limited bandwidth pink noise.
The unit's frequency response is not particularly wide. Once again, limited bandwidth pink would get around the limitation. The frequency response is not particularly flat, either, which is another downside. You don't really know where the problems are.
Finally, a sound meter should be of the "true RMS" type. Not all are. A true RMS meter will respond to something called "crest factor" in a different way than a cheaper averaging type of meter. The higher the crest factor, the more the error can be. Crest factor is higher with fullband pink noise than with limited band pink. (Crest factor is like a ratio between instantaneous peak levels and average levels.) The specs don't say which type this is, based on its cost I'd guess it is an averaging type of meter. The difference is hopefully small with limited band pink noise but a good quality pink noise could reveal up to 1 db of error.
In my mind the errors can all add up to a big problem, or they could all cancel each other out. I don't know, no way to really know! It is certainly better than no meter at all but there is a point where something that is cheap is just TOO cheap. When you add up all the possible errors, it seems likely this is not going to be very accurate. You could easily make a measurement that is several db different than a good meter would show you.
Old 09-22-2010, 06:57 PM
Craig F Craig F is offline
I would get one of these http://www.bksv.com/Products/SoundLe...2250Light.aspx
Thank you,
Craig
Old 09-23-2010, 05:27 PM
mikevarela mikevarela is offline
Food for thought...
Grab a SyncCheck and use it's onboard SPL meter. Save some cash and get the video offset functionality as well
NuanceTone.com
HTML code is On
Dorrough Meters calibration zzstation Post - Surround - Video 14 10-31-2010 11:05 AM
Monitor Calibration and Room Compensation. donrey Pro Tools TDM Systems (Mac) 3 09-18-2006 11:46 AM
Calibration in a small room... joeyk Post - Surround - Video 3 05-08-2006 10:02 PM
Room Calibration and Levels for LE Starcrash Post - Surround - Video 8 08-03-2005 10:40 AM
192 calibration and VU meters Digitrove Post - Surround - Video 23 10-19-2004 02:29 PM
