Old 09-01-2002, 08:14 PM
EDurney EDurney is offline
Default -9093 error, please!!!!
i really don`t know what to do, i get this all the time.
This is my 3rd computer with Pro Tools, and is the same error, all the time...what can i do?
my PC is:
A7V333 mobo
athlon XP 1800
256 ddr ram
maxtor ata 133 80gb drive.
XP os
when i used W98, was exactly the same, well, XP
seems to be more stable, but i got this error anyway.
any advice wiil be well received,
please, help me out with this.
a Chilean friend
Edo Durney
Pro Tools 10 / Duet 2 - Eleven Rack - Mbox 2 pro
MacBook Pro 2.2ghz Quad Core/ 8gb RAM/ 750HD
Pro Tools 9 HD / 192io / C24
Mac Pro Quad 2.66 / 8Gb Ram
Old 09-02-2002, 12:22 AM
audio junkie audio junkie is offline
Default Re: -9093 error, please!!!!
I just solved my 9093 problem after about a year. Here is what I would try first.
1. Try using Microsofts standard IDE driver instead of the one for you MB. Also check to see if there's updates for your MB.
2. Try using your ATA management utility (if you have one) to change your drives from ATA133 to ATA 66 or even ATA 33. Thats what finally fixed my problems.
3. Check for IRQ conflicts. Try using a specific harware windows configuration that has eveything but you vid card and DIGI dissabled.
4.Make sure there's nothing running in the background (cntrl+Alt+Del and see what all shows up) If you have too, run msconfig from the run box and dissable everything you don't need in your startup selections.
5. If your using a promise controller, or a RAID array, thats prob your problem.
Search further for 9093,9094 erros and you'll find this is a very popular problem.
Hope this gets it, check back if it doesn't
Where ever you go, there you are.
Old 09-02-2002, 09:52 AM
Thans for your reply Audio Junkie, i will try that, everybody is saying that is the Ata controller, i have used different ones, it`s the same!!....any other ideas??
Old 09-02-2002, 11:44 AM
yea, I think its your ATA controller. No seriously, thats what mine was, just took me forever to figure out how to set it to ata 33 mode.....What kind of drive is it?
Old 09-03-2002, 05:54 PM
Well, my drive is a maxtor ata 133 7200rpm
How can i do that on XP??? i can´t find the way to do that ( put the disc to work as a ata 33 or 66)
Old 09-03-2002, 08:58 PM
yea, Mine was a WD that was at 133, and they have a ATA management utility on there intall disk. I don't think I got one with my Maxotor. I'd check with Maxtor on that, see how its done. If you can't I don't know what to tell you, I was trying to figure it out for a while myself. I'm pretty sure thats what it is...
Old 09-17-2002, 09:39 PM
Some People tells me that i can fix this error buying an external Promise controller is that right?
any success stories???
Old 09-17-2002, 11:23 PM
Sorry your still haveing this problem, I pulled my hair out for almost a year. It really sucked. I was dancing when I finally fixed it.
I've read of some problems with the Promise controllers, but I haven't done research on the good side. Search the DUC. one thing I know would work is to get a Firewire enclosure for your drive. I'm about to do this myself.. there cheap. Start at like 40 bucks. Just make sure you get one with the Oxford 911 chipset. It makes anydrive an external Firewire drive. And there hotswappable too!!!
Digi was no help to me, as it seams with most people with this problem. Did you make any headway with your problem?
Old 09-18-2002, 12:28 AM
Roly Roly is offline
I just put my hard drives on the IDEs and put my CD and DVD on the promise controller.
Are you using ATA100 cables?
cheers Roly
Error 9093- Need some help... cclarkaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-21-2008 06:02 PM
DAE ERROR 9093 Babu1210 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-05-2007 01:16 PM
ERROR -9093 Soth41 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-11-2003 11:19 AM
error 9093 FernandoJMercado 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 01-03-2003 07:03 PM
1 Cure for error 6085 and error 9093!!!!!!!!! CraigD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-23-2002 07:30 AM
