Old 10-17-2021, 05:58 PM
[email protected] Curtis2Smith@Gmail.com is offline
Default New Build w/ Older Rack
I recently built AMD Ryzen 5 3400G w/ Aesus X570 MB, Windows 10, wanted to add Firewire PCIe to interface 003 Rack + (LE 8.05) but after researching it looks like this hardware isn't even supported anymore. Can I update Pro Tools ?(Not sure how or if it is even compatible with Windows 10.) Admittedly I haven't been involved for years, but pertinent info doesn't seem easily deciphered, and I can't say Avid is exactly chomping at the bit for person to person help. Any info about my options would be appreciated.
Old 10-18-2021, 07:39 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: New Build w/ Older Rack
You can take a look at the Pro Tools Operating System Compatibility Chart to see which versions of Pro Tools are compatible with which OS version.
Here is a link to the Pro Tools System Requirements as well.
Hope that helps and please ask any other questions you may have about compatibility.
Will
System Details
Old 10-18-2021, 08:48 AM
The odds of the 003rack working are actually pretty good. But you will need newer PT software. IIRC, 12.4 or 12.5 is the first version to be compatible with Windows 10.
Old 10-19-2021, 02:56 PM
zedhed's Avatar
zedhed zedhed is offline
I'm still on v11.3.2 (The last version before subscription model) and whilst not 'officially' compatible, it works fine on Win10.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Older 11 rack and newer version Sam C Eleven Rack 6 04-02-2013 07:37 PM
003 rack comp build. Need some info... geekkiller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 04-18-2010 02:32 PM
003 Rack - Windows 7 - New Build lowlights 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 11-13-2009 03:03 PM
Possible i5 Build for PT LE 8.0.1 / 003 Rack lowlights 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 11-13-2009 02:44 PM
Build your own isolation rack case? bwherry General Discussion 7 11-28-2003 11:18 PM
