Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 07-05-2021, 05:08 PM
abt abt is offline
Default HD OMNI input gain control doesn't work
I'm not liking the look of this. The input gain knob for both inputs 1 and 2 is not working on my omni.
- When the gain knob is turned the display changes but the gain doesn't
- The input level on the meter does not change
- I've tried resetting the unit
- Pad still works
- Phantom power still works
- Both the front and rear mic inputs have the same issue
- The instrument input also has the issue
- The rear line in is working
As the rear line in is working I can use another mic preamp to bypass the omni pres and still use the interface.
So far to me it look like hardware failure. I'm hoping someone here might have a fix for me but it doesn't look good.
Old 07-07-2021, 11:37 PM
abt abt is offline
Default Re: HD OMNI input gain control doesn't work
Oh well, it was worth a shot...
I also found these two threads. Look like it's dead.
http://duc.avid.com/showthread.php?t=357367
https://duc.avid.com/showthread.php?t=326284&page=2
Old 02-19-2022, 08:00 AM
HrvojeCro HrvojeCro is offline
This is an already known problem, it is a problem with the microphone preamp, I have repaired several such devices. Certain components need to be replaced, this must be done by a service technician who has smd soldering equipment and who has a lot of experience.
HD Omni line input gain adjustment bissodj Pro Tools HDX & HD Native Systems (Win) 4 02-02-2014 02:00 AM
New Omni....Pre Amp Gain Knob Doesn't Work tomhartman Pro Tools HDX & HD Native Systems (Mac) 4 05-16-2012 06:51 PM
OMNI - "control-able mic gain? clusterer Pro Tools TDM Systems (Mac) 5 02-24-2011 02:47 AM
control 24 input gain not working crawdak Pro Tools TDM Systems (Mac) 9 08-05-2010 10:08 PM
Input gain control 002 rack help zman76 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-17-2004 08:36 PM
