Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 06-29-2021, 09:46 AM
apologetics apologetics is offline
Default Mbox Pro 3 not receiving signal from Windows 10, after 1-2 seconds connected.
Hi, I am owning Mbox Pro 3, and I am having problem receiving sound from my PC, Windows 10.
I've installed 1.1.10 mbox pro driver from avid website. When I turn on my Mbox Pro 3, mbox pro control pannel receives signal and projects sound about one to two seconds, and sometimes about 30 seconds long too. But thats it, and it goes off. Not receiving any signal after that! Sometimes after five minute it just randomly start receiving signal and project sound about 1-2 seconds again and goes off...
Does anyone knows how to solve this problem? Its really weird that it catches sound at first and receiving it in control pannel (and project sound at speaker too) well for few seconds, but goes off and not receiving any afterwards...
Please help me!
Old 06-29-2021, 11:15 AM
unkJE's Avatar
unkJE unkJE is offline
Default Re: Mbox Pro 3 not receiving signal from Windows 10, after 1-2 seconds connected.
Welcome to the community
Try a new cable from Mbox 3 Pro to your computer –
I have Firewire cable > SIIG FireWire 2-Port ExpressCard > laptop
I hope it’s just a bad cable – and not the Mbox 3 Pro!
In Control Panel > Sounds > Playback tab
set your Onboard Sound as Default (hit OK)
In Control Panel > Sounds > Recording tab
set your Mbox Pro 3 as Default (hit OK)
Restart computer
Always turn Mbox Pro 3 and computer off before connecting or disconnecting Firewire cable
Turn Mbox Pro 3 on - then turn computer on
Pro Tools Studio 2024.3 * Studio One Pro 6.6 * Harrison Mixbus 10 Pro * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 & Air 32 MINI * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock * 3 TB Samsung SSDs * 3 Screens: 15.6” Laptop & 24” BENQ LED GL2450-B & Samsung 27” CT550 curved Monitor
Old 10-13-2023, 06:23 PM
kordtone kordtone is offline
Me too. I'm on my second Mbox 3 Pro this month and still getting no software signal back. I think it's somthing to do with Windows 10 and how it's built today vs how it was built in 2014. Avid hasn't released an update for Windows in years so it's safe to assume it's a lost cause. Would of just got a new interface like a Scarlett but I already spent $100 bucks on a Thunderbolt 2 to Firewire converter and a Thunderbolt 2 to Thunderbolt 3 converter from Apple and I'm just justifying the purchase. Plus out of ALL of my DAWs, Pro Tools is the only one that doesn't play nice with my Liquid Saffire 56, or other 3rd party interfaces on Windows. So it might be time for me and Avid to part ways.
Old 03-11-2024, 07:42 AM
legacygt777 legacygt777 is offline
Please help me!
I would try and reinstall everything again. It worked for me on Win 10.
Old 03-11-2024, 11:55 AM
+1 for trying a new cable(I had one fail for no reason at all) and maybe check the power supply to make sure its plugged in all the way and doesn't have any breaks in the wire. You might also try the other firewire drivers that are available in Windows. Avid recommends the Legacy driver, but that never worked correctly for me(with 002/003). Since I had a FW card with a TI chipset, the TI Compliant driver worked for the 002/003. I currently have an Mbox 2 Pro working on Windows 11 with a VIA firewire chipset. These used to not work, but it works fine here(I know its all different, but it may give you some hope)
Old 03-12-2024, 01:33 AM
unkJE's Avatar
These work best with my laptop:
Avid Mbox Pro Driver Version 1.1.10
https://avidtech.my.salesforce-sites...ox-Pro-Drivers
SIIG FireWire 2-Port ExpressCard - 2 FireWire 400 (6-pin) ports for multiple device connections
https://www.siig.com/firewire-2-port...scard-949.html
Mbox 3/Pro Tools Express receiving signal in interface but not showing up on PT ukuleleism FireWire & USB Audio Interfaces (Win) 1 12-27-2014 03:11 AM
Artist Mix Only Stays Connected for about 20 seconds zeroclip Artist Series 8 10-30-2014 12:23 AM
No MIDI signal when connected via MBox bhospelh FireWire & USB Audio Interfaces (Win) 5 09-14-2014 06:56 PM
Aux not receiving bus signal [Solved] arturoinletto Pro Tools 11 2 01-14-2014 07:34 PM
Mbox (3G) is receiving signal, making white noise, and clipping while sitting idle. schumann1000 Pro Tools M-Powered (Win) 1 06-06-2011 11:44 AM
