Old 08-25-2001, 02:18 PM
Thou Thou is offline
Default Digi Outs work fine---Logic not getting signal to outs
Greetings........
I am using Logic Platinum as the front end...I run my analog equipment thru a mackie 24/8...out, into any pair of Digi 001 analog ins....I do see the signal in Logic on the 2 channels,,,but nothing is at Logics master outs, which causes no sound out....and I'm trying to send the outs to my Korg 168Digital board via lightpipe.But if I actually record something(audio or midi),when I play it back...I can hear it.And yes the inputs on the channels are on the correct input and output.
It seems everything is set right because I do get the signal into Logic.
Is there a setting that I'm missing or something ?
Thank U 4 Your Help
Thou(Artist/Producer) http://home.earthlink.net/~tunednlife
Old 08-25-2001, 03:53 PM
Kickin.da.speaker Kickin.da.speaker is offline
Default Re: Digi Outs work fine---Logic not getting signal to outs
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR> when I play it back...I can hear it <HR></BLOCKQUOTE>
You mean you can't?
How about your logic environment, are you sure your track is cabled into your master output track?
If you still have the problem simplify your rig to troubleshoot: create an environment from scratch with one audio track going into one master track.....do you have signal in both? then from that, just build your mixer, add more tracks, add buses, and so on. It's a good exercise anyway to understand the architecture of your mixer [img]images/icons/grin.gif[/img]
However, if you don't want to go through that hassle, gimme your email and I'll email you my environment, I knoe it does work. Sounds good?
David.
6am eternal
Old 08-29-2001, 02:15 PM
Thanks Kickin'.......
I went from scratch in the environment and I really know what makes things tick now...it's fine now,thanks to your help......
Old 08-29-2001, 02:52 PM
Cool.
Remember: to troubleshoot, make it simple. It's easy.
Glad to see it worked for you.
David.
6am eternal
Digi002 rack main outs vs monitor outs studiojb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-03-2012 07:46 AM
Problem with 002 main outs as well as head phone outs? wiseal1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-10-2009 11:36 AM
Logic pro 8 and Digi coreaudio still 8 ins/outs ? crizdee Pro Tools TDM Systems (Mac) 1 11-30-2007 08:26 AM
LOGIC AUDIO 4.8 with DIGI 001 ( Optical Outs ) gavmac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-14-2002 12:59 AM
Logic Audio Gold 4.8 with DIGI 001 ( Optical Outs ) gavmac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-13-2002 02:26 PM
