Bounce to Disk confusion PT 12.
Hi, I am totally confused by the Bounce to Disk options offered on my PT system (12.8.1)
I am trying to do a simple LR bounce (with Bus and Master inserts) to get a project up to typical Mastering levels. I do this all the time though I haven't used PT in a few months. I expect to see a Bounce Source pull down menu so I can indicate O/P 1-2 (for example) as opposed to the Track Source, which is not what I want. Thinking I am losing my mind, I went online and ALL the instructions say to look for this pull down menu. There simply isn't this option anymore. Its not like its blank or greyed out, it simply ISN'T THERE. I see it in the pulldown menu in the QT Bounce option but (obviously) I don't want a QT Movie. For reference, I tried the QT Bounce and the levels are what I would expect. Where did this pull down option go? Has this workflow changed recently? What am I missing here? All I want is to render my Master OP to an audio file and it seems I can't anymore. Please help. thx |
Re: Bounce to Disk confusion PT 12.
There is track bounce which is different from session bounce. For session bounce I normally just select in the edit window the length I want to bounce then in the mix window right click on the Master faders output assignment which brings up the bounce to disk box that should have the options you are looking for. The track bounce works similarly as you can right click in the particular tracks output button.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
Bounce to Disk: Bounce to disk length is longer than my track on my time | dijitalhorse | Pro Tools M-Powered (Mac) | 1 | 02-23-2016 06:27 AM |
Some confusion about bouncing to disk and dither | miketheman83 | Windows | 4 | 04-27-2013 11:12 AM |
Confusion about Bounce To Disk in Low Latency Mode | Jperkins | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 08-13-2009 03:15 PM |
Help! Hard disk confusion | DodgyDave | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-20-2003 12:23 AM |
Help! Hard disk confusion | DodgyDave | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-19-2003 02:24 PM |
