Old 08-24-2017, 01:18 PM
christhechive christhechive is offline
Default Pro tools glitching even on high buffer size
Hi everyone
I have a Protools on PC problem I'd love some help with.
I've just updated to a new PC running Protools 11.3.1 on. I've been a Protools using for over 10 years and was previously using an i5 based PC that worked well but ran out of power on bigger projects.
My new machine is based round an i7 7800X processor (full spec below) built to the spec of a respected DAW computer building firm. My problem is even as high 512 I'm getting audio glitching so bad the sound is almost unrecognisable. This is on a session with one guitar amp sim and one VI piano playing in real time. I also have Reaper which I use a little and the same instance runs flawlessly at 64 samples as do stand alone V.I.s (I'd be grateful for 128 tracking with PT). I'm using an RME UCX with this.
The computer has been set up to run within Avid's recommended setting as far as I can see.
If anybody has any wisdom I'd be most grateful
Many thanks
Chris
PC spec
Motherboard ASUS PRIME X299-A
Processor Intel Core i7 7800X "Skylake-X" Six Core 3.5 GHz (4.0 GHz Turbo)
Memory 16GB Corsair Vengeance 2400MHz DDR4
Graphics Card NVIDIA GT 710
Power Supply 550W EVGA G2
System Drive 500GB Samsung 850 Evo SSD
Storage Drive 2 x 1TB Seagate
Optical Drive LG 24x DVD-RW
Operating System Microsoft Windows 10 Home 64bit
Old 08-25-2017, 09:10 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Pro tools glitching even on high buffer size
Please don't DOUBLE POST.
See my reply in your other thread.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 08-25-2017, 09:03 PM
albee1952 albee1952 is online now
+1 for not double-posting. I may be off-base here, but a 550 watt PSU seems pretty wimpy for a modern-day powerhouse computer Current-starving components can give crappy performance(learned the hard way a few years ago) I currently run a 750 watt PSU(system below)
High Buffer settings with Command 8 and Pro Tools 10 tj2toxic ProControl, Control|24, Command|8 1 08-08-2013 04:34 AM
High Buffer settings with Command 8 and Pro Tools 10 tj2toxic Pro Tools 10 1 07-30-2013 01:25 PM
Mbox Buffer Size Too High, Can It Be Lowered? pittsburgh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-30-2008 12:04 AM
Increase Buffer size/Decrease Buffer size? kerick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-28-2006 12:00 AM
Increase buffer size...decrease buffer size.... Bodhisan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-08-2005 07:24 PM
