Old 03-16-2015, 07:40 PM
shacke shacke is offline
Default Working with two tempos
Help please! I just realised that have two tempos on a song i'm working on. I only noticed it when I tried to add a new part and the click track wasn't in time. It must have happened when I changed the tempo but somewhere along the timeline the old tempo remained. So the song starts at 86bpm and after 6 bars it changes to 88bpm and it looks like it gradually goes back to 86bpm at the end. The song should be 86bpm. I've tried using elastic audio but it isn't working, maybe i'm not doing it right? Does anyone have any suggestions please? Is it something I can fix in PT? I've laid loads of live instruments and vocals and dread having to do it all again. I'm running PT10 on Mountain Lion. Thanks.
Old 03-16-2015, 08:39 PM
dr_daw's Avatar
dr_daw dr_daw is offline
Default Re: Working with two tempos
Just insert a tempo change at those points, or create a groove template from your rhythm section and use beat detective or elastic audio to lock to that template.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
Old 03-17-2015, 01:50 AM
Thanks dr_daw, i'll give it a try.
matching tempos - help!! alexruimy General Discussion 5 07-15-2011 05:25 PM
Need help matching different tempos lalalandguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-05-2009 11:08 PM
Can You Use Two Tempos In One Session?? jayrussell Tips & Tricks 2 03-12-2008 09:10 PM
match Tempos ModaRecords Pro Tools TDM Systems (Mac) 3 02-07-2005 05:03 PM
tempos over 300? mike connelly Pro Tools TDM Systems (Mac) 2 11-17-2000 11:56 AM
