Old 10-17-2014, 09:50 AM
shacke shacke is offline
Default Distorted vocals
Hi, i've just upgraded from PT8LE to PT10, using MBox2 Pro with a Mac running 10.6.8
After recording vocals, I find they are sounding fuzzy and distorted although the levels are all fine, no clipping or anything. I therefore suspect the the signal was distorted even before it got to the recording stage.
Any help would be appreciated please, thanks.
Old 10-17-2014, 10:06 AM
Default Re: Distorted vocals
So the tracks were recorded elsewhere? If you did the recording, describe the entire chain(sometimes, folks new to recording make mistakes such as connecting an external preamp to the Mbox XLR input, or as crazy as renting an expensive mic, but singing into the wrong side of it yes, I've seen that too).
Sadly, once they are overdriven(maybe at the mic, or at the preamp), there's not a lot that can be done(but if someone has an idea, I'm keen to learn) Maybe you can turn this around by using the distortion and going for a unique sound like some of ZZTop's stuff, or Foghat, where the vocals are distorted? If the music just doesn't lend itself to that kind of "sound", your best bet may be to re-track vocals.
Old 10-17-2014, 10:16 AM
I recorded them myself. I'm not using an external preamp, just the Mbox 2 Pro with mic plugged into XLR. Everything was fine with the exact same rig-up yesterday when I still recorded on my PT8LE. However today i've upgraded to 10 and everything looks fine but after tracking some vocals I play them back to hear they're a bit fuzzy and distorted. I have a feeling it is something to do with I/O settings as I had to re-do them but just can't see what it could be. I will have to retrack but trying to see if anyone has an idea how I can fix this.
De-clipper - Distorted Vocals ?? KingFish General Discussion 4 12-31-2010 03:23 PM
vocals sound distorted on record but play back fine dougbiggs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-06-2010 10:32 PM
HELP with Distorted Vocals session48 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-30-2009 10:41 PM
Distorted / Tape / Valve Amp Vocals Matt Darcy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-21-2008 07:59 AM
Any tips on blending old vocals with new vocals? Somebody Pro Tools TDM Systems (Mac) 5 06-07-2000 08:38 AM
