Old 04-19-2013, 01:18 PM
peter5992 peter5992 is offline
Default Consolidating / exporting a session
Good afternoon everyone:
I am (nearly) finished downmixing a 5.1 music mix for a documentary to a stereo mix of approx 48 minutes total runtime. All the final cues (rendered in the session) are lined up sequentially in just one stereo track, and all other tracks (A and B rolls, split into dozens of mono tracks) are removed.
I want to send the rendered cues as well as the final downsized session to my composer, however when I do a 'save copy in' apparently all the audio files that were in the original file are copied and I end up with a whopping nearly 8 GB session.
Am I wrong in thinking that "save copy in" only copies those clips from the bin that are actually used, or does it still copy everything ever used in any previous session even if those clips and the tracks have been removed?
If so, what is the workaround, should I right click in the bin and select and remove everything (only from the session) that is no longer used, or maybe create a new session and import just this one stereo track?
Thanks!
Old 04-19-2013, 03:18 PM
C C is offline
Default Re: Consolidating / exporting a session
Main Playlist Only is the setting you are looking for in the Save Copy In dialog.
Ceri Thomas
Personal Site
Mix Tech/Assistant Sound Editor
Old 04-19-2013, 07:44 PM
Awesome -- that's it.
You are my hero Ceri!!
Old 04-20-2013, 08:55 AM
joachim's Avatar
joachim joachim is offline
In your "save copy in"-session you could go further reducing the data amount by
deleting unused audio in the clip list
selecting all remaining clips in the clip list and choose "compress".
It will "consolidate" every clip to its own length.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
HTML code is On
Need Region names to remain the same as original when consolidating and exporting! dkstudios Pro Tools TDM Systems (Mac) 0 01-23-2012 09:31 AM
Consolidating audio for a session? pennyco Pro Tools TDM Systems (Mac) 3 02-03-2011 12:51 PM
Consolidating PTLE Tracks for HD Session jamesbaxter Pro Tools TDM Systems (Mac) 2 05-08-2007 10:52 AM
Consolidating & Save Session Copy In Dave Collins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-04-2005 09:23 AM
If I edit files after exporting to 2nd session, how is 1st session affected? el biciclista 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-02-2002 12:01 AM
