Old 03-29-2011, 01:00 PM
sode sode is offline
Default Export region as files
Hi
I have a problem. In Pro Tools 9.
How do I Export region as files from the "timeline"?
It was possible in version 8 hitting cmd+shift K
Best from
Thomas
Old 03-29-2011, 01:07 PM
SteveWitt SteveWitt is offline
Default Re: Export region as files
cmd-shift-3 will consolidate a track's regions, thus creating a single wav which can be located or dragged out of the session. Is that any use?
Old 03-29-2011, 01:11 PM
fakir_cz fakir_cz is offline
I've just RTFM and it also said Cmd+Shift+K. I'm not able to test it at the moment, so can't help more.
edit: actually, consolidate is Option+Shift+3.
Tom
BcA. Tomas Vitha
Sound Designer and Mixer
2010 Mac Pro 8-core Westmere, OS X 10.6.6, PT HD 9.0.3, Mbox 2 Pro, C|24
Old 03-29-2011, 01:48 PM
true dat
Old 03-29-2011, 02:37 PM
Thank you and true with Option+Shift+3.
And then I can Export from Region list to the right.
But that is so time consuming. And not what I want.
It was so easy in PT8.
Any ideas?
Thomas
Old 03-29-2011, 04:11 PM
KMcK KMcK is offline
Command+Shift+K still works in PT9, it hasn't changed since PT8. I use it all the time.
Old 03-29-2011, 04:35 PM
Any ideas?
Try trashing the preferences, it might quite likely help. It's almost universal cure for most "not behaving as it should"-type of problems. IMO, Avid should teach Pro Tools how to trash the prefs itself and periodically, just to stay in good condition.
Tom
BcA. Tomas Vitha
Old 03-29-2011, 05:42 PM
Preferences: Editing: Region List Selection Follows Edit Selection
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 04-01-2011, 02:35 AM
Thank you all.
I trashed the pref. files and now it is working.
export region as file BUG? lukeyy Pro Tools TDM Systems (Mac) 0 12-04-2010 10:46 AM
New bug: Can not export region files Alιcio Costa Pro Tools TDM Systems (Mac) 2 02-23-2008 06:02 AM
MIDI Region Export nikki-k Tips & Tricks 4 07-26-2006 11:14 PM
Region Groups... Export as Files?!? Why not? NylonOxygen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-20-2006 11:21 AM
bounce to disk vs. Export region as files abraxas Tips & Tricks 6 09-02-2001 05:09 AM
