Old 07-12-2010, 12:11 PM
Fuzzyc Fuzzyc is offline
Default Transferring sessions between Mac and PC
I Can anyone explain how to transfer sessions between the Mac and the PC?would like to be able to collaborate with a band member that is running Pro Tools on a Mac (I'm on a PC running Windows 7).
I wish I could help but I'm not as familiar with Mac as a PR
Thanks!!
Last edited by Fuzzyc; 04-15-2023 at 05:25 PM. Reason: Wasn't involved in this thread.
Old 07-14-2010, 03:22 PM
solitaire349 solitaire349 is offline
Default Re: Transferring sessions between Mac and PC
I've been wanting to do this my self, just read this in the pro tools 101 book but haven't tried it my self yet so I don't know if it will work, or if there is something else needed to be done...but go to file->save copy in->then fill out the boxes. select the save as type drop down menu (in case you have an earlier version of pro tools). choose the audio file format for wav I guess and then there should be a box to check for "enforce MAC/PC Compatibility"
Old 07-15-2010, 08:07 AM
scenicrecords scenicrecords is offline
If you are transferring with a Flash Drive or a External Hard Drive, make sure you format it to FAT32. Only FAT32 will read/write on both systems. If you are formatting it on a Mac using the Disk Utility, I think the choice is MS-DOS.
Dell Studio 1555 Laptop, Intel Core Duo T6600 2.2GHz, 4GB RAM
Windows 7 64-bit
Pro Tools M-Powered 8.0.4cs2
M-Audio Firewire 410 via Digi-Qualified SIIG FireWire 2-Port ExpressCard {NN-EC2012-S1}
Glyph 050Q 500GB via eSATA
Old 07-15-2010, 12:32 PM
Dism Dism is offline
I transfer PT sessions between Mac and PC all the time with no issues. Never had to check "enforce Mac/PC compatibility." YMMV.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 07-15-2010, 03:10 PM
TOM@METRO's Avatar
Same here, I get Mac drives (HFS+) all the time with no issues. I never use FAT 32 anymore. Just be sure you have checked the box on your PT installation for HFS+ support.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 07-15-2010, 05:10 PM
I did not know there was a way to read HFS+ on Windows.
Windows 7 64-bit
Old 07-15-2010, 05:27 PM
You guys must be using LE or HD. I just found this in the M-Powered setup guide:
Pro Tools M-Powered does not support the following
Pro Tools LE options:
• Complete Production Toolkit
• DV Toolkit 2
• Digidesign Ethernet-based control surfaces
(such as C|24™)
• Avid video peripherals
HFS+ Disk Support
Windows 7 64-bit
Old 07-16-2010, 07:21 AM
We've been able to easily transfer the wav files back and forth without any problem, but not real sure how to transfer the "session". Dism - do you mind sharing some tips on how you do that?
Also, one of our challenges has been that when we have a track that is placed in the middle of a song (and doesn't start from the beginning), when you send just the wav file its placed at the beginning of the song when you import it into PT. So you have to manually move that track into place. If you have several wav files it gets to be a pain. Can you help me with that as well?
Many thanks!!
Old 07-16-2010, 07:49 AM
Just grab the whole session folder... put it on your next system, open it. That's all there is to it.
Many thanks!!
This won't be a problem when you open the actual session... but it's good to know for when you need to bounce to other DAWs. Pro Tools is particularly good at this.
Simply:
Select all regions in question, from the very end. Hold Shift and press Enter (Return on Mac). This creates a selection from 0 on your timeline to the end of your regions. Consolidate regions (shift+alt+3). What this does, is puts silent "space" before your regions so that they all start at 0. Export Regions as Files... and now you have wavs that can be imported to any DAW and will all be lined up.
D
Old 07-16-2010, 09:28 AM
Thanks Dism! That is a big help! I'll give it a try later today.
Model: PC AudioLabs Rok Box i9
OS: Windows 10 64 Bit
CPU: Intel(R) Core(TM) i9-9900KF CPU @ 3.60GHz
Memory: 32GB
Internal Hard Drives:
500GB= Programs
1TBGB= Audio
1tbGB= Samples/Back Up
External Hard Drives: Verbatim 1TB USB Drive
RME Fireface UFX Interface/Preamps
Pro Tools 2023
Focal CMS 65 Monitors
Avantones
Transferring sessions gteam Pro Tools TDM Systems (Mac) 5 04-05-2008 10:50 PM
transferring sessions between pc and mac philywily Tips & Tricks 2 02-26-2006 05:58 PM
Transferring Sessions KRUSH GROOVE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-19-2005 12:08 AM
transferring sessions from PC to MAC ? Dan Downs Pro Tools TDM Systems (Mac) 3 10-20-2003 03:22 PM
transferring sessions q... JEdmunds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-04-2003 03:36 PM
