No Midi output
I am having an issue with my MIDI in PT. I am running Windows 7 and have Pro Tools 8.0.1 with an original mbox. I realise that there is a further upgrade to 8.0.3 but my mbox won't be compatible
The problem is quite simple: I cannot get PT to send midi to any external ports. I have quintuple checked that I am sending to the right place in the channel I/O and I have made sure that all of my external racks are receiving on channel 1. It makes no difference whether I set up an instrument in PT midi studio or just directly out of the MIDI interface. I have tried three different bits of hardware - mbox2 (borrowed for troubleshooting), midiman 2x2 (nightmare just to find the correct driver) and a MOTU express XT. All have the same problem - input to PT is fine but no output possible anywhere. PT will also not receive any midi unless 'midi through' is checked in PT. I don't remember it being like this before. I would really appreciate help as I am at my wits end. Thanks. |
Re: No Midi output
I have the same problem. PT 8.0.3, Windows 7 beta drivers, mbox 2 mini
Re: No Midi output
After numerous re-install and the same result, I searched the Windows HD forum and found the solution:
SOLUTION Been having trouble getting MIDI out of PT 8 on a Vista platform myself and finally found a solution!! (From Avid Support's Knowledge Base) Run as Administrator This can help with a variety of MIDI issues (i.e., no MIDI output or HUI communication) and using the ASIO Digidesign Driver in third-party DAW's. Right-click on the problematic application's icon on your desktop. Choose Run as Administrator. To permanently run an application as an administrator Right-click on the problematic application's icon on your desktop. Choose Properties. Click on the Shortcut tab. Click on Advanced. Check the box that says “Run as administrator”. Click OK. |
Single MIDI Track Output to Multiple MIDI Channels? | jb_trm | Pro Tools 9 | 2 | 07-11-2014 09:09 AM |
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input | yellow | Eleven Rack | 1 | 05-04-2012 03:33 PM |
No MIDI output in PT 9.02 | emmen | Windows | 11 | 04-23-2011 06:31 PM |
MIDI Output Problem - Assigning MIDI Patch Names | pancake1975 | MIDI | 8 | 05-29-2006 03:25 PM |
2 MIDI Input Tracks Output to Same MIDI Channel | altemir | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-05-2005 03:20 PM |
