Old 12-21-2009, 12:44 PM
lonestars lonestars is offline
Default Electrcity problems?
Hi!, I'm having electricity problems in mi 003 rack +.
It happens in two of the three places where I mix.
Several times, while mixing, when a switch light is turned on or off in one of these places, Ptools crashes with H/W buffer size errors (and is to max), or other strange 0x00008nnnn errors, but only in this case, switching on or off a light in home or muy grildfriends home.
Both homes have a non old electricity system...
May be the digi003 power supply have a problem?
I have a new mac book pro with full battery.
Any suggestion?
Thanks!,
Lonestars
Old 12-21-2009, 02:45 PM
SpinningDisk's Avatar
SpinningDisk SpinningDisk is offline
Default Re: Electrcity problems?
Don't touch the light switch. It doesn't sound like 003. Sounds like you need to call an electrician.
Disk
Old 12-21-2009, 03:37 PM
Disk
+1 on the electrician visit. I highly recommend a UPS or a high end power conditioner that not only protect against surges but one that actually keep the voltage at the proper levels. In other words it prevents voltage overages as well as (more importantly) prevents voltage underages by augmenting the electrical voltage with back-up batteries or capacitors when needed. It iwll cost you some scratch but it will be better than replacing the 003 and any other equipment you are using.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 12-21-2009, 11:13 PM
b mcgibney b mcgibney is offline
At the very least spend a few bucks for a circuit tester to make sure stuff is wired right and then a simple digital multimeter to see if the the supply volts are at least between 110 and 130. If not ---work somewhere else. Clean power really helps
B
Pro Tools Studio 2023.12, RME UFX, Mac studio and a bunch of nice noise makers
Old 12-21-2009, 11:17 PM
sunburst79 sunburst79 is offline
Get UPS.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Midi Studio Setup problems & Plugin problems J Nauti MIDI 0 03-02-2010 11:04 AM
Computer Problems vs Pro Tools Problems mudlake slim Pro Tools M-Powered (Win) 1 07-14-2006 08:09 PM
Rewinding Problems, Cutting & Pasting Problems Nikki 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-22-2005 01:19 PM
Problems, Problems, Problems all day long... Jperkins Pro Tools TDM Systems (Mac) 5 05-12-2005 07:58 AM
PC Probe problems. Any overheatingg problems with Digi 001 Ajay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-03-2002 05:30 PM
