Re: Help w/sequencer and Pro Tools
I guess no one has an answer for me, oh well
So your giving up? What about the beat clock? Is your keyboard capable of receiving the beat clock. When I had my Alesis HR-16 drum machine, I just turned on the beat clock so when ever I hit the space bar it would start. You have to try the trial and error system unless someone know that keyboard. You may have to just bounce in your audio from the key board and drag the wave forms to line up with your grids if you want to use other instruments, IE: (VST). Go out from your key board into your ins on your 003. Record. Some keyboards can be synced to PT. I have a Motif ES 8 and have been trying for three years to make it work. It has its own sequencer. I got it to work once but it almost froze my computer so I said, I'll just use it four sounds. Give it a little more time. Good luck.
Disk |
thanks, for your advice, i am not giving up its just that i dont wont to try without some advice first, when i wrote oh well thats what i meant, that i was going to try it on my own, like u said trial and error
one more thing the Roland MC50 is not a keyboard its a hardware sequencer and the roland R8 is a drum machine, i need to sync both of these to Pro Tools at the same time
This is not specific to the MC50 (it's for MPC), but this post includes the kind of info you need to set up MIDI sync:
http://duc.digidesign.com/showthread.php?t=243075 You need to decide a couple things; like what is going to be the master sequencer -- ProTools, or the MC50? Is the MC50 currently triggering the drum machine? Are you going to transfer the MIDI from the MC50 to ProTools and then trigger the drum machine from PT? Describe the specifics of your session a bit better... Read through that post and see if it makes sense for your situation..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
#16
My experience:
Send MIDI clock (aka SPP, do not mixup with MTC) to external devices: PT LE: + Reaper: + Ableton Live: + Send variable tempo to external devices: PT LE: + Reaper: + Ableton Live: + Accept MIDI clock (aka SPP, do not mixup with MTC) from external devices: PT LE: - Reaper: + Ableton Live: + Accept variable tempo from external devices: PT LE: - Reaper: - Ableton Live: +
macpro 2.6ghz, 4gb ram, osx 10.6.1, macbookpro 2.5ghz, 4gb ram, osx 10.5.8 mbox2pro, mbox2micro, emu1616, protools8le, reaper, logic express, axiompro49, padkontrol, rode nt2-a, lexicon mx300, uad2laptop r3, microQ, Albino3, impOSCar, Structure m1active 520 & sub gw s750, deq230, cx2310 |
#17
I would like Pro Tools to be the master, and yes the MC50 Triggers the drum Machine, does it make a difference which one is the master, the reason i said i would like pro tools to be the master is because i do all my starting and stopping from Pro tools. and thank you all again for your help, Merry Xmas to all
#18
Flommer I read the thread you mentioned and yes it makes sense, thank you, do i need to do additional configuration for the following. Pro tools as master, triggering the MC50 and the MC50 triggering the Drum Machine?
again thanks for your help |
#19
will the setup describe in my previous post work?
#20
spidey, you're probably just gonna have to screw around with it and try to get things sync'd up. Unless somebody has the same hardware and is trying to use it in the same way you are probably not going to get specific info.
I will say that I think you should try to get the MC50 out of the process. Get your MIDI recorded into PT and then just depend on sequencing in PT... PT can then trigger the Drum machine, too..
Using Pro Tools as sequencer for BFD...help! | jasonguitar | Pro Tools M-Powered (Win) | 7 | 02-06-2007 01:42 PM |
Using Pro Tools As My Sequencer | strizzack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-20-2005 01:29 AM |
Best sequencer for Pro Tools HD | marindakim | MIDI | 3 | 04-15-2003 05:22 AM |
Transfering note data from a sequencer to the sequencer of the digi 001 sequencer? | MichaelK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-05-2000 12:29 AM |
Pro Tools 5.0 Sequencer!!!!! | black magic | General Discussion | 12 | 08-19-2000 11:07 AM |
