Old 04-05-2008, 09:05 AM
gtrplyr1 gtrplyr1 is offline
Default Pro Tools and EZDrummer Help Please !
Hi ... I'm running Pro Tools LE 7.1.1 on a Intel Mac (2.16 GHz Core 2 Duo) with 2 Gigs of RAM. I'm using the latest version of EZ Drummer and I have the following expansions installed:
Vintage Rock
Rock/Pop
Nashville
Latin Percussion
Cocktail
So I'm having all kinds of MIDI issues. I'm quite familiar with Pro Tools when it comes to audio but MIDI is not one of my strong points. I have sequencers in the past and have decent knowledge of MIDI operations but what I'm dealing with makes no sense.
Here are some problems:
I put EZdrummer on a stereo instrument track and set the input to "No Input" ... so far so good. Now I'll set up some different patterns for verse - pre chorus- chorus .... that's fine ... now I'll go to put a fill between verse and pre-chorus .. let's say a 2 beat fill and as soon as I pull that in the drum parts in the pre chorus go nuts .... the measure after the fill disappears ??? Shouldn't it simply drop in filling the 2 beats before the next section ? I do have MIDI merge selected (don't know if it makes any difference ... dosen't seem to ) ... so then I undo and try again and sometimes it drops right in but then sections well after stop working !!!
I've also tried to put a crash at the beginning of a new section by moving a ride ... as soon as I move that note anywhere the rest of the MIDI data in the measure disappears !!!
Just MIDI HELL !!!! So far they should call this EZHeadache .... but I have a feeling the problem is with Pro Tools not EZDrummer .... in any case any thoughts would be greatly appreciated !!!!
-Gtrplyr
Old 04-05-2008, 10:41 AM
GunnyT GunnyT is offline
Default Re: Pro Tools and EZDrummer Help Please !
gtrplyr,
You might have better luck posting this in either the Virtual Instrument or MIDI Forums, or both. Lots of good info there.
Good luck.
Where in the world is DJ Reggie?
Old 04-06-2008, 10:59 PM
eyrespace eyrespace is offline
It's not a protools issue, but an EZ drummer one. The fill you are dropping in has a silent section. I don't know why they chose to do this but the easy solution is to create another midi track and drag your fill to this track. Use grid mode to select the fill, omitting the silent section, copy and paste into you drum track.
regards
EyreSpace
Old 04-07-2008, 12:48 PM
The Dougfather The Dougfather is offline
Hi , i can help on this one because i have contacted toontrack tech support about it. If you switch your midi over to region view it's a little more clear.
Even if you drag and drop a 2 bar fill, EZ drummer always drops in 4 bars, so thats two bars of useless silence. This happens in logic as well not just Pro Tools. Tech support told me the best workflow was to create an empty midi track to use for editing and then transfer the correct midi to the required location. Kind of annoying but it really isn't a biggie when you get used to it.
Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Pro Tools 11 and EZdrummer btwnthbttns AAX Plug-ins 11 12-07-2013 04:55 PM
Pro Tools LE 8 and EZDrummer, PLEASE HELP! Darkostica 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 23 09-21-2011 02:27 PM
EZdrummer no sound in pro tools 8 flintclint Pro Tools M-Powered (Win) 5 11-21-2010 12:09 PM
EZDrummer and Pro Tools 7.4 (Please Help) JMH Virtual Instruments 2 07-04-2008 03:40 AM
ezDrummer and pro tools??? robotboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-15-2006 01:00 AM
