Old 07-28-2005, 06:19 AM
JoeLo JoeLo is offline
Default Buzzing During Playback
Hello all, I just bought my MBox and have loaded ProTools into my computer without a hitch. I am running off XP and have a question. I get a clear signal through the monitors when recording but when I playback the sound it is all distorted. The signal has not redlined, my latency settings are low, I am not using a preamp or a stereo but am directly connected to the MBox with a guitar. My sample rate is 44.1kHz and the bit depth is 24 bits. Last night, I had to switch the bit depth to 16 bits in order to get a clean playback signal. Is there something else I should look into to record at 24 bits? Any suggestions or advice would be appreciated.
Old 07-28-2005, 09:17 AM
DigiTechSupt's Avatar
Default Re: Buzzing During Playback
Please provide specific information about your computer - processor type, chipset model, attached peripherals, etc.
The noise issue you're describing is usually related to not having Service Pack 1 installed - is that possibly the case?
Avid Audio Tech Support
Support FAQ
Old 07-28-2005, 11:23 AM
I am running at 730 megs, with a Pentium III processor, 512 SRAM and 9 gigs. This computer was never used for any other type of program except for ProTools. It was specifically saved until I had bought the MBox and Pro Tools program. I do not have it connected to the internet so I do not believe I have SP1 installed. I suppose that I can dl it from Microsoft to a disc from a different computer and run the disc into it to see if that is the problem. Thanks for helping.
Buzzing Sound During Recording and Playback Tman311 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-22-2014 06:53 PM
Low Buzzing During Recording and Playback carterisgod41 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-07-2011 02:40 PM
Buzzing during audio playback Cary_Clark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-20-2008 11:42 AM
Buzzing during audio playback Cary_Clark Pro Tools TDM Systems (Mac) 0 06-13-2008 12:01 PM
Buzzing on Playback??? JRodJr Pro Tools M-Powered (Mac) 0 03-21-2006 07:19 PM
