Digi002 problems after updgrading to PT 6.4
My Digi002 is not being recognized. This happened after I opened my first PT session in 6.4 and downloaded the new firmware.
The long story... is that I upgraded my 933 quicksilver g4 tower to panther and to PT version 6.4. I then proceeded to open a prior session , upon doing so a dialog box asked me if I would like to download the latest firmware (warning me that this could take a long time). I clicked yes, and waited for the firmware to be updated. That was last night. Everything was working fine (I only upgraded so I could have the automatic delay compensation). I continued working on that session for about an hour longer. When I was done with the last of edits I closed the session, quit pro tools and shut off my digi 002 (in that order) Today is a whole new world of not recognizing my digi002 The little green firewire led does not stay lit ( it lights up for a second when I turn the machine off and on and or plug in a cable) I cannot even enter standalone mod Troubleshooting done already upgrade core audio to 6.5.2 Switch firewire cables unplug turn off HELP!!! thank you in advance charles Mundelein |
Re: Digi002 problems after updgrading to PT 6.4
hi,
a few day ago i had a similar hardware problem. during a session a error message like this appears: Could not communicate with the Digi002. ok, i closed the session, but the Digi002 doesn't respond. i switched it off and on again, but nothing nothing on the channel scribble strip - no wlecome, no digi002,... nothing also no light, on all buttons,... also no reaction if i press a button, also the standalone mode won't work,... pfuh, for a second i run in panic. ok, i switched of the Digi002 again, unplugged everything (also the power c.), i switched it on for ~20sec.(without power!!), after that procedure everything woks normaly on the Digi002 but there is also still the bounce problem: Assertion error , "FF_AudioProperty.cpp," line 33 i hope it helps bye |
G5 Dual 1.8 /1.5 Gb Ram OSX 10.4.7 PT LE 7.3 cs1 DIGI 002 Waves Ren Sony Bundle Soundtoys-arama NI Komplete 3 |
digi002 problems | 3d-minor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-14-2011 03:37 PM |
OS Updgrading Best Practices... | proxy | Pro Tools TDM Systems (Mac) | 6 | 09-16-2006 06:46 AM |
Digi002 Problems... HELP!!! | Jsswtpmp182 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-22-2006 06:57 AM |
Updgrading from Power PC to G3 / G4 | worldsend | Pro Tools TDM Systems (Mac) | 2 | 09-11-2005 02:05 AM |
Few Digi002 Problems | Vertigo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-31-2003 01:31 AM |
