Old 06-17-2010, 10:45 AM
billybroadsword billybroadsword is offline
Default No Midi output
I am having an issue with my MIDI in PT. I am running Windows 7 and have Pro Tools 8.0.1 with an original mbox. I realise that there is a further upgrade to 8.0.3 but my mbox won't be compatible
The problem is quite simple: I cannot get PT to send midi to any external ports. I have quintuple checked that I am sending to the right place in the channel I/O and I have made sure that all of my external racks are receiving on channel 1.
It makes no difference whether I set up an instrument in PT midi studio or just directly out of the MIDI interface.
I have tried three different bits of hardware - mbox2 (borrowed for troubleshooting), midiman 2x2 (nightmare just to find the correct driver) and a MOTU express XT. All have the same problem - input to PT is fine but no output possible anywhere.
PT will also not receive any midi unless 'midi through' is checked in PT. I don't remember it being like this before.
I would really appreciate help as I am at my wits end.
Thanks.
Old 06-26-2010, 09:53 AM
who who is offline
Default Re: No Midi output
I have the same problem. PT 8.0.3, Windows 7 beta drivers, mbox 2 mini
Old 06-27-2010, 07:25 AM
who who is offline
After numerous re-install and the same result, I searched the Windows HD forum and found the solution:
SOLUTION
Been having trouble getting MIDI out of PT 8 on a Vista platform myself and finally found a solution!!
(From Avid Support's Knowledge Base)
Run as Administrator
This can help with a variety of MIDI issues (i.e., no MIDI output or HUI communication) and using the ASIO Digidesign Driver in third-party DAW's.
Right-click on the problematic application's icon on your desktop.
Choose Run as Administrator.
To permanently run an application as an administrator
Choose Properties.
Click on the Shortcut tab.
Click on Advanced.
Check the box that says “Run as administrator”.
Click OK.
Single MIDI Track Output to Multiple MIDI Channels? jb_trm Pro Tools 9 2 07-11-2014 09:09 AM
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input yellow Eleven Rack 1 05-04-2012 03:33 PM
No MIDI output in PT 9.02 emmen Windows 11 04-23-2011 06:31 PM
MIDI Output Problem - Assigning MIDI Patch Names pancake1975 MIDI 8 05-29-2006 03:25 PM
2 MIDI Input Tracks Output to Same MIDI Channel altemir 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-05-2005 03:20 PM
